It is currently Tue Oct 17, 2017 4:06 am
 Post subject: Noise suppressor ground.
PostPosted: Sun May 03, 2015 8:50 pm
Where precisely is it grounded? I know (per workshop mamual) it's grounded to the chassis. But where precisely? Is it maybe inside the car?
Anyone knows what happens if it's not grounded or poorly grounded?
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Sun May 03, 2015 10:28 pm
It's the little black thing under the ignition coil
I think it goes body to top of tranny
I've never ran one(the wires always corode)
Never had any issues
08 Civic Wife's car
PostPosted: Mon May 04, 2015 5:06 am
the 2 wire block that's mounted to the coil bracket is a diode. the noise suppressor is located on the left hand strut tower where it meets the firewall and has 3 wires. it shunts the ground from the coil's secondary to ground through a capacitor/ resistor network which remove electrical noise from the signal coming out on the third wire that drives the tachometer.
if it is not grounded the coil tries to discharge through the tack which generally kills it.
the actual ground wire runs back into the harness and joins several other ground wires before terminating at a chassis point. that makes the actual answer of where the noise suppressor ground point is, internally, in the wiring loom for the front chassis. :wink:
PostPosted: Tue May 05, 2015 7:22 am
:oops:
08 Civic Wife's car
