It is currently Sat Jan 20, 2018 10:17 am
PostPosted: Mon May 04, 2015 9:59 am
I have an easy way of removing the starter shaft bushings from their end housings.
Using a tap and turning it into the old bushing will remove the starter shaft bushings
with little effort and do it quickly. Clean the bushing holes of there old grease and
Press the new bushings in place.. Thats it! 12 mm and a 14 mm taps for our starters.
Fainya
PostPosted: Tue May 05, 2015 10:12 pm
THEIR!!! THEIR end housings... not THERE. THEIR!! I can't handle this misspelling anymore!!! I know that when spoken, they sound the same, BUT THEY ARE NOT THE *%&$#@! SAME!!!!
PostPosted: Wed May 06, 2015 5:29 am
Thanks for the tip fainya, another tech tip learned from you. :mrgreen:
PostPosted: Wed May 06, 2015 7:58 am
There, Their, everything will be vine............
PostPosted: Wed May 06, 2015 10:10 am
'' in vane'' :-P
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Sat May 09, 2015 3:07 am
I stand corrected in their error.
Fainya
PostPosted: Sat May 09, 2015 1:13 pm
Don't forget they're. :lol: :lol: :lol:
