It is currently Tue Jan 16, 2018 6:47 am
PostPosted: Sun May 24, 2015 10:29 am
hi,i'm giorgio from italy,i have this problem of my swift :
i don't have power for injector from the ECM,the ECM and all sensor is ok,i have only 0.2V TO INJECTOR.
can you help me please,thanks.
Sorry for my english :vibe:
PostPosted: Sun May 24, 2015 11:02 am
try cleaning the ground connections on the back side of the intake manifold.
power comes from the fi relay in the relay and fuse rack under the hood located on the left side strut tower. check the smaller 15 amp fuse in that box as well. the ecu "sinks" current from the injectors, i.e. - it takes the injectors to ground to make them fire.
PostPosted: Mon May 25, 2015 12:06 pm
thanks for the reply but I tried it and does not start, the relay 'and the smaller is ok, the injectors are ok lacks only 5V by the control unit
