It is currently Thu Oct 19, 2017 8:02 am
PostPosted: Wed Aug 03, 2016 2:39 pm
I had an ignition problem with a 91 vert. I swapped out the column, no problem. Now I only have headlights when I use the high beam on the steering column. Unless the lenses are so bad that I can't see it, or I have another problem. It passed inspection and it probably shouldn't have. Al
PostPosted: Thu Aug 04, 2016 7:28 pm
Most likely has a burned connector at fuse box. Pull the connectors you plugged in with steering column and you may find one that is clearly melted. There is an easy fix on here somewhere, using a different larger pin to offer headlight ground since the factory one is to small and overheats over the years.
PostPosted: Sun Aug 07, 2016 8:24 am
Sweet, I can easily do that, there were only three. Now to try some of the headlight lens buffing stuff, I may be able to see at night. Our weather here has been so perfect at night, 70's clear and warm, I want to drive around all night.
PostPosted: Sun Aug 07, 2016 2:56 pm
Before you buy headlight cleaner, try some toothpaste. Put on damp cloth. Rub onto lens in straight back and forth strokes until feel is smooth.. then buff off residue with dry cloth.
PostPosted: Tue Aug 09, 2016 4:44 pm
i attended geopalooza just this past weekend and the guys there were doing a great job cleaning the yellowed plastic composite headlights with cutter's insect repellent.
apparently high concentrations of deet do a superb job of restoring the plastic lenses. ;)
and there are zero abrasive particles in the bug spray.
cron
