It is currently Fri Oct 20, 2017 1:04 am
PostPosted: Thu Jun 02, 2005 12:08 am
Senior Member
I was working on Tim's intake & 60mm throttle body mod again tonight and got down to the throttle cable arm mod. I modified it exactly like mine of which I run a Hitachi 60mm TB. Went to install it on his TB and found the hole was way too small to fit the shaft :evil: :evil:
Tim bought a Unisia Jecs 60mm throttle body off some Nissan. Dan should be able to tell us what motor and car it came from; I don't know. I will make it work with some additional machining, but it is a pain in the ass.
Moral of this story is, do not buy anything but a Hitachi long shaft 60mm TB for this motor or you will create way more work for yourself than is necessary.
Later,
Mike
PostPosted: Thu Jun 02, 2005 11:46 pm
Deadbeat
Deadbeat
lol my car is a frankenstein, all kinds of custom parts added in, i will be burnin rubber though once its complete
1999 G13B Metro
lotta Mods
2002 Sentra SE-R
intake/header/exhaust/cams/pulley
PostPosted: Fri Jun 03, 2005 11:43 pm
Senior Member
Modified throttle cable arm on Tim's 60mm TB. Lots of grinding to make it fit right. Also note this TB has heavier springs than the Hitachi TB. Tim will have to tell us if the gas pedal is OK or hurts his foot :lol: I installed both springs for safety. If one of them breaks, then there is another to close the throttle plate :shock:
Mike
PostPosted: Fri Jun 03, 2005 11:49 pm
Deadbeat
Deadbeat
its beautiful.. :worship: hopefully, i never have to worry about that spring breaking :-/ im just ready to have this baby on my car
1999 G13B Metro
lotta Mods
2002 Sentra SE-R
PostPosted: Sat Jun 04, 2005 12:01 am
Senior Member
Here is the bone stock Unisia Jecs 60mm TB.
Mike
PostPosted: Sat Jun 04, 2005 1:22 am
Senior Member
Tim's mod IAS. Note two grooves carved to use old coolant tubes for the new idle air bypass hoses. JB Weld bridge to isolate the two tubes. Mount this assembly on an aluminum plate with a 90 bend in it. Use RTV to seal.
Mike
PostPosted: Mon Jun 06, 2005 1:39 pm
Deadbeat
Deadbeat
just a reminder of how much bigger my 60mm tb will be
http://www.teamswift.net/album_page.php?pic_id=3950
1999 G13B Metro
lotta Mods
2002 Sentra SE-R
PostPosted: Tue Jun 07, 2005 2:30 am
Senior Member
Shown are the mods from stock to finished to fit the 16v SOHC G13B. Note TPS shaft mod.
Mike
PostPosted: Sun Jun 12, 2005 12:03 am
Senior Member
And the final result.
Mike
PostPosted: Mon Jun 13, 2005 12:25 pm
Deadbeat
Deadbeat
ok don't everyone say anything at once... no "sweet, nice work" or "you da man!"
i will be the first to say, YOU DA MAN MIKE!!
1999 G13B Metro
lotta Mods
2002 Sentra SE-R
PostPosted: Fri Jun 17, 2005 10:54 pm
Deadbeat
Deadbeat
guys i have just installed the assembly you see above, and my god... its awesome, you could not believe the gains in torque and horsepower this gave me, its crazy, i suggest this mod to any 16 valve sohc
1999 G13B Metro
lotta Mods
2002 Sentra SE-R
PostPosted: Fri Jun 17, 2005 11:16 pm
Senior Member
I guess I just took for granted that the cam was the #1 part that would turn the 16v SOHC G13B into what it should have been. I had installed the cam, mod intake & 60mm TB all at once so didn't realize what each component would do for individual gains. Can't imagine how nice the header will work with these parts...well I bet she it gonna gain a pile of HP/TQ once again. Now what else can we come up with that will add some more zip to the car? I better get mine together so I can test the APEXi out. I know the fuel curve is messed up with the factory computer running the motor so there has to be some gains with a tuned fuel curve...
Mike 8)
PostPosted: Wed Sep 14, 2005 2:40 pm
any idea on where i can purchase one of thsoe 60MM throttle bodies? for my 1998 metro LSI 4D
PostPosted: Wed Jan 24, 2007 9:24 pm
so, what amount of power are u guys getting from these mods?
PostPosted: Mon Oct 13, 2008 6:23 pm
I have another intake in spare and I would to put a 60mm tb on it. But it is necessary to oversize the inlet of the intake to fix the tb on it ? And for the tps, what it the major modification to do for it ? The bolt paterb it is the same ?
http://www.qcswiftclub.com
Ps:Sorry for my bad english
PostPosted: Tue Oct 14, 2008 6:50 am
this is a real blast from the past,,, lol :lol: im still wondering though, how much power has anyone seen from these kind of mods ?
PostPosted: Mon Apr 23, 2012 11:46 am
Senior Member
All my pictures are gone :( Was there a server change that got rid of pics that were uploaded rather than linked from a personal server? I don't think I can find all those old pics to update this thread again. Sorry.
Mike
2006 Ion Redline Competition --- HP>MPG
2012 Prius Four Solar Plus Performance --- MPG>HP
