Hi, I'm new around here
I was wandering in a wrecking yard and found a 95-97 mk4 with a tach cluster so I kind of "borrowed" it in the idea of placing it in my 2000.
At first it didn't work, half the indicators would not light, the speedometer didn't work and most of all the tach didn't respond either. So I removed it and began an analysis of the two clusters, there's a slight difference between the two models in power distribution, I found out the power source is the same for all indicators and gauges on my 2000 cluster while there are two for the older model (or is it only because there is a tachometer maybe?) Anyways, I just wanted to add that instead of using the far left red/yellow wire wich is the interior light system, you could use the almost far opposite one, for instance the second on the right wich is black/white and is hot on start.
Now the power is back and everithing works fine, except the tachometer lol, I thought it would use the same wire as the older model (brown wire, eight from left on the same connector) but it seems not to work, either that wire does not have any signal or the cluster is defective.
I spent some time surfing the web in search of the wiring diagram and almost gave up but guess what, I found something wonderful at
http://swift.crime.one.pl/pliki/schematy/
these are pdf files of all wiring diagrams for the swift from 1989 to 2001
I'll try taking the signal straight from the ecs as you proposed, what bugs me is that the wire is brown and therefore it is highly probable that it's the same I was using without result.
Well, I hope I helped somebody, at least it was pleasant for me, see ya guys
Bob
