It is currently Fri Oct 20, 2017 7:00 pm
 Post subject: trouble code po136
PostPosted: Sun Jul 23, 2006 4:46 pm
any suggestions what can cause this code cleared it a couple of times it comes back on after i drive about 10KM. it sputters at about quater throttle but if you put it to full throttle the sputter goes away.
im lost
 Post subject: Re: trouble code po136
PostPosted: Sun Jul 23, 2006 9:16 pm
abby normal
im lost
Please include year / make / model / engine / transmission / when posting. It is easier to find information on the car. :wink:
P0136 is a generic trouble code for 1 of the 2 oxygen sensors used on the car--
You may want to check the connectors on the o2 sensors and make sure they are seated properly.
With the engine off, disconnect and connect the sensors several times to seat the pins. at the
same time, check the connectors for water or oil contamination.
Good luck :)
