It is currently Sun Oct 22, 2017 7:47 am
PostPosted: Wed May 14, 2008 2:19 pm
has anyone gotten one of these? they have ones that weigh 11 lbs my stock batt weighs 28-30 lbs and the price on tirerack is bout 150 not to bad...and from what ive read they can handle small 4bangers like ours...nice lil lightweight mod.
HANSTECH
member of team
PostPosted: Wed May 14, 2008 6:35 pm
I used a similar one (it was a snowmobile battery actually) in my Stealth TT and it started that car with no problem whatsoever. I tried it in my modded Camaro SS with stock internals, 12:1 compression H/C package and it started OK as long as I charged it fully before taking it to the track. It did not last very long (6 months) in the Camaro however. It lasted over a year in the Stealth. I plan on getting one of these for my 95 Swift as part of the performance enhancing mods because weight savings help everything.
PostPosted: Wed May 14, 2008 11:15 pm
Maybe Nitro (or someone who knows) will post. I remember he had a tiny little red battery in his MK1 build.
Scott
Its not lag, its suspense...
1987 mk1 T3
PostPosted: Thu May 15, 2008 9:05 am
and i do belive they have atleast a 1yr warranty. im gna get one next month...i'll keep with updates. so far ive dropped about 125 lbs outta of my 01 swift. cant wait for more!!!
HANSTECH
member of team
PostPosted: Wed Sep 24, 2008 3:04 am
You could also get a 200cca Deka ETX14 battery. Same thing. 11.5lbs.
I'll be interested in a) how you mount it, and b) how you start your car in winter.
PostPosted: Wed Sep 24, 2008 12:37 pm
well ive held off on getting one, i figure mine works fine, so i will wait till mine needs to be replaced before getting a lw batt. but i will let you know.
HANSTECH
member of team
PostPosted: Fri Oct 22, 2010 10:08 pm
$20 lawn mower battery from walmart 1/3to1/2 the weight:
for $60-100 or so they have gel cells that would be better, but I'm cheap, works just like the original starts fast, no issues.
