It is currently Mon Oct 16, 2017 8:02 pm
PostPosted: Thu Jun 05, 2008 10:24 pm
This is keeping from getting my Virginia inspection: no reverse lights.
I checked one of the bulbs, it was fine. I checked the 15 amp fuse labeled BACK in the interior fuse block.
So I'm thinking it might be the "backup switch" located on top of the transmission? Is this just a matter of unscrewing the old one and screwing in a new one... they look they run about $20 from the dealer.
Thoughts?
98 1.3 manual.
 Post subject: Re: No reverse lights...
PostPosted: Fri Jun 06, 2008 6:10 am
I had the exact same thing on the exact same car. Just replaced the switch. Same as replacing a sparkplug, actually easier, it's not down in that six inch tunnel.
PostPosted: Sat Jun 07, 2008 1:53 am
Thoughts?
98 1.3 manual.
i actually had this problem and the GM dealer fixed it. its the switch.
PostPosted: Sat Jun 07, 2008 6:14 am
I've ordered the switch online from a dealer in Texas, $16.44 plus $8 shipping. It will take a few days to receive; I'll post when I install it.
The switches available on Ebay, too.
PostPosted: Sat Jun 07, 2008 8:27 am
So where do you go next when the switch tests good, bulbs are good, but still no reverse lights?
Right front turnsignal is starting to act up in the same way.....
-jw
PostPosted: Sat Jun 07, 2008 11:52 am
you didn't mention the fuse....
PostPosted: Tue Jun 10, 2008 8:28 pm
-jw
You start tracing the wiring harness.
PostPosted: Wed Jun 11, 2008 9:06 pm
-jw
Eh, crap, I figured as much.
PostPosted: Tue Jun 17, 2008 10:28 am
It was the switch. The lights work perfectly now.
It was hard to get down to the switch to tighten it though -- it's in a tighter spot than at first appears -- thoughts?
PostPosted: Sun Oct 31, 2010 1:39 pm
Hey ... I have the same problem on my 91 Metro ... No reverse lights.
Can I have a pic of the switch and the location please?? :!:
PostPosted: Sun Oct 31, 2010 1:50 pm
this post is over 2 years old. :lol:
isn't this the reverse light switch? on the front of the transmission between the blue clutch cable mount on the left and the black coolant pipe on the right.
PostPosted: Sun Oct 31, 2010 4:22 pm
Thanx a lot ... checking it now
PostPosted: Tue Nov 02, 2010 3:10 pm
t3 ragtop wrote:
...isn't this the reverse light switch? on the front of the transmission between the blue clutch cable mount on the left and the black coolant pipe on the right...
Yes it is!
