It is currently Sun Feb 18, 2018 4:48 pm
 Post subject: bad harmonic balancer?
PostPosted: Thu Jun 03, 2010 2:35 pm
my old 99tro lsi has a bad one. is it a must fix now thing? and also how hard to replace?
HANSTECH
member of team
PostPosted: Fri Jun 04, 2010 1:09 am
never heard of one going bad. What is it doing? They really dont give any issues. Easy to replace, five bolts and its off. Are you sure its not the crank bolt loose? Thats common.
PostPosted: Fri Jun 04, 2010 9:14 am
well the crank is moving around quite a bit. wobble wobble. i think its due to the cat being really plugged up. the girl driving it fails at all things car related. she ruins everything!!
HANSTECH
member of team
PostPosted: Fri Jun 04, 2010 12:27 pm
I'd check to see if the crank bolt isn't loose and that wobble isn't the pulley beating the stuffing out of the woodruff key/keyway.
PostPosted: Fri Jun 04, 2010 1:23 pm
good call. i will have to check it out sometime.
HANSTECH
member of team
PostPosted: Wed Jun 16, 2010 12:13 pm
Do it ASAP or it'll ruin the crankshaft and pulley :( (if its loose)
PostPosted: Wed Jul 14, 2010 2:25 pm
The problem was the driver. Just like with the Cherokee, the Camry, and the Jetta. No mechanical issues, all user error.
