It is currently Sat Feb 24, 2018 1:50 am
PostPosted: Tue Jun 29, 2010 2:39 pm
I just bought a 98 metro for $250 and its sitting on lowering springs. The struts are blown and was wondering if the aftermarket accomadated the 98 and up with a strut that would work well with the lowering springs?
$100 95 Geo Metro Hatch, $150 91 Geo Metro Hatch, $300 90 Geo Metro Wagon, $250 98 Chevy Metro Hatch = Cheapest Fun Ever (All with 1.0's)
Suzuki G1.0, setting the bar for hybrids since 85'
PostPosted: Tue Jun 29, 2010 3:36 pm
Pics of ride would be welcome.
KYB struts.
PostPosted: Tue Jun 29, 2010 7:25 pm
keep in mind that the kyb gr-2 struts' warranty only works for a drop of up to 1.4".
PostPosted: Tue Jun 29, 2010 9:03 pm
Since the KYB's are designed for the lower mk2/3 cars, dropping a mk4/5 1.5" puts it only 1/2" lower than the older cars, IIRC
My cars:
PostPosted: Tue Jul 06, 2010 3:35 am
With the mk2/3 kyb gr-2's, would the shaft diameter be correct when installing on mk 4/5? I know that there is more weight in the newer cars vs the older cars and didn't know if you would have to exchange the strut mounts...
PostPosted: Tue Jul 06, 2010 4:18 am
Shaft diameter is the same. Only difference is the springs are different to take the added weight, and the length of everything that goes out to the wheel is a bit longer for the increased track, axle, tie rod, control arm.
PostPosted: Tue Jul 06, 2010 3:42 pm
http://cgi.ebay.com/ebaymotors/KYB-4-GR ... ccessories
