It is currently Sun Oct 22, 2017 8:47 am
PostPosted: Fri Jul 23, 2010 10:19 am
Hi guys, first time poster.
I just bought a 97 Metro Base 1.0L 3-cylinder 5 speed hatchback and I'm trying to get it fully ship shape. The check engine light is on and the mechanic I took it to told me that the Catalytic Converter was bad, and that there were codes for the EGR system. He suggested that I not spend the money to fix the problems if the car was running well. I read the FAQ on cleaning the EGR and I was wondering if everything that was in that post viewtopic.php?f=2&t=25919 applied to the 97. What would be the best place to buy a replacement Catalytic Converter for a 97 1.0L 3-cylinder?
PostPosted: Fri Jul 23, 2010 10:28 am
'95 to '97 should be the same. You can purchase a cat a any automotive store (NAPA, Pep boys, etc...). Phone around to get the best price.
Ralph
PostPosted: Fri Jul 23, 2010 12:02 pm
http://www.hottexhaust.com/detail.asp?PRODUCT_ID=91004
Probably the cheapest you can find, and it will not trip any codes if you have a secondary O2 sensor.
My cars:
PostPosted: Fri Jul 23, 2010 1:10 pm
My mechanic warned me that non-oem cats can trip a warning light. I'm not exactly handy with cars (trying to learn). Is it worth it to use a direct fit cat or just go with the cheaper universal?
PostPosted: Fri Jul 23, 2010 1:50 pm
The Smuggler
Bull crap if you buy a good brand Converter and not the cheapest one you can find on ebay, you will be ok.
Walker stands by there converters and build them to more than cover the emmissions on your car.
and FYI the Converter on your car was OE built by Tenneco who owns the brand Walker Exhaust.
Direct fit if available is just as good as a universal.
Only the universal will have to be welded into your system using the existing pipes.
Walker direct fit # is 55174 and meets the US federal emmissions standards. (Except California)
And I love this one!
PostPosted: Fri Jul 23, 2010 3:24 pm
55174 also comes with the downpipe and the first section of pipe to be a direct bolt in replacement.
The exhaust shop I went to, told me the same thing, then quoted me almost $2000.00 to replace the exhaust on a Beetle. I walked out, ordered the magnaflow replacement, a replacement downpipe, put in a free flowing muffler/resonator, stainless steel pipe, all welded up and installed, with no codes(98 Beetle and it's computer is far more fussy than the Suzuki one in yours) all for around a $1000.
My cars:
PostPosted: Fri Jul 23, 2010 4:15 pm
Follow your mechanic's advice; he's the best one to learn from as well, not us.
If you take the advice from stranger's on a website over his, he might become angry and charge you exorbitant rates, eh?
So play it safe, and just do what he tells you.
After you've got some experience, or have read a great deal on the subject, you can either do the work yourself, or become an apprentice, eventually mastering the material needed to fix and repair all the systems in your car.
Hope this helps.
Good Luck!
:lol: :lol: :lol:
PostPosted: Fri Jul 23, 2010 8:35 pm
Have a look at your exhaust system. If it's welded together and not bolted you may be better off having a shop weld in a universal cat but be careful of the amount they want to charge you for this. I have bought complete replacement exhaust from my local parts store (NAPA) from exhaust manifold back. It all bolts together and the cost for the complete system here (500 miles from the warehouses) was $480 Canadian including taxes.
Ralph.
PostPosted: Sun Aug 01, 2010 9:46 am
how can you tell if the convertor has gone bad, did it stasrt running bad?
PostPosted: Sun Aug 01, 2010 4:38 pm
It stays out late, won't tell you where it's been, it smells of beer and has tobacco stains on the heat shield. :mrgreen:
