It is currently Fri Oct 20, 2017 11:29 am
 Post subject: 1.0 injector flow rate?
PostPosted: Tue Sep 14, 2010 5:10 pm
I can't seem to find the flow rate for these injectors anywhere. I'm using an aftermarket inline fuel pump in a buggy application and need to make sure my pump flows enough. The engine is from a '99.
PostPosted: Tue Sep 14, 2010 5:26 pm
290cc/ min. they are the red ones aren't they?
PostPosted: Thu Sep 30, 2010 6:13 pm
pull off the return line and replace it with a loop of clear plastic tube
run the engine
if there are no bubbles in the return line , AND the fuel pump can maintain correct fuel pressure
it is up to the job
the fuel pump flow should never change , it is flowing at max for the system all the time , the fuel pressure regulator just dumps excess fuel back to the tank
all the time the engine is running or the fuel pump is "on" .
as long as the return flow is uninterrupted AND fuel pressure is at spec . the system has enough fuel for it's needs.
PostPosted: Fri Sep 30, 2011 12:21 pm
run the engine
it is up to the job
not all fuel systems have a return line, and need fuel pump voltage adjustable based on fuel needs for the motor
95 G10 manual hatchback. ZERO RUST!
WANT TO DO: underbody brace, strut bars, all bushings, springs and struts, wheels and tires
PM me if you have a general car or computer question!
PostPosted: Fri Sep 30, 2011 1:47 pm
true but none of these cars use returnless fuel systems with a PWM pump. so the advice given in this thread is valid.
it wont take much pump to keep up with a 1.0 just install a pressure gauge and if it falls below spec at high rpm/load youll need a bigger pump.
PostPosted: Sun May 27, 2012 1:23 am
290cc at what psi?
