It is currently Wed Oct 18, 2017 5:14 pm
PostPosted: Sun Nov 14, 2010 4:40 pm
Team,
My son's Chevy Metro has developed a high pitched squeal/whine after it gets fully warmed up... I read other posts and people were saying it could be the alternator, belt or both. Some even blamed the water pump...
The water pump is brand new (Rock Auto), the alternator belt as well as the timing belt and tensioner have all been replaced.
To rule out the belts, or any associated bearing issues, after the car is at operating temperature, I pulled both the air conditioning and alternator belts, but yet the whine returns! Can't be alternator, water pump, or air conditioning.
I sprayed WD-40 around intake gasket, throttle body, fuel injectors, and etc to rule out a potential vacuum leak. Even replaced vacuum hoses...
The thing only whines/squeals when the RPM returns to idle. If you kick on the a/c or turn on the lights, you hear the load go on the engine, and whine stops. Once you return everything to normal, the whine is there.
Any ideas???
Steve
"Remember the days when racing was dangerous and sex was safe?"
1997 Geo Metro 1.0L/5-Speed
PostPosted: Sun Nov 14, 2010 10:07 pm
The Smuggler
is your car a manual?
If so does the noise change when you use the clutch pedal?
Have you checked the oil level in the transmission lately?
on the manual transmission the throwout bearing can be really nosiy at idle if it had been touching the clutch fingers because of improper adjustment.
it will wear out the bearing prematurely.
and when it gets dry it will squeal.
And I love this one!
PostPosted: Sun Nov 14, 2010 11:59 pm
Forgot to mention that it's the dreaded 3 speed automatic... :shock:
Anyway, it's not the alternator belt because I pulled it completely off the car along with the a/c belt... Fired her up and what do you know, the noise/whine returned!
So that leaves me ponder what else it could be?
Thanks for your inputs so far.
Steve
PostPosted: Mon Nov 15, 2010 4:22 am
Remove the timing cover and try it again. If it persists, while the engine is running, spray WD40 in different areas, including into the alternator, and listen for the noise to go away (before you start putting things back on the engine). If the noise persists it could be internal so listen carefully to where the sound is coming from and get back to us. From what you have done so far I would begin to suspect the timing belt tensioner, even if it was replaced.
PostPosted: Wed Nov 17, 2010 8:14 am
Considering you have eliminated drive belts, I would look at the following areas.
Timing belt cover rubbing on crank pulley.
Timing belt adjusted to tight.
PCV valve.
Vacuum lines. pinch them off with needle nose pliers to see if whine stops or changes pitch
Brake booster. Again pinch off vacuum hose.
Power steering pump. Low fluid? If your car is equipped with P/S.
Automatic transmission pickup tube to filter. The upper o ring is above the fluid level and if it
gets old it will pickup air and cause a transmission whine.
Use a long piece of vacuum hose to your ear and with the other end, probe the engine compartment to locate the source of the offending whine.
Fainya
PostPosted: Wed Nov 17, 2010 2:57 pm
Thanks for all the replies!
Unfortunately, I haven't had time to troubleshoot the past couple of days...
I agree with all of you suggesting the timing belt tensioner... This only started after I installed the new timing belt and tensioner.
I will keep you notified of progress.
Steve
PostPosted: Wed Nov 17, 2010 3:36 pm
I hate to be this guy but....
Are you sure its not your wife whining in the passenger seat???
Most people call my cars Junk.
94 Geo Metro 4dr G10 357k miles
95 Ford Taurus GL Vulcan 298k miles
88 Nissan 300zx n/a 2+2 181k miles
1989 Ford F-150 5.0 4x4 (my 4wd Mustang) Lord only knows how many miles
PostPosted: Sat Nov 20, 2010 12:57 am
I was watching a porn flick with this gal on the bed whining. Do you know what shut her up?
A D--K in her mouth..
Fainya
