It is currently Wed Oct 18, 2017 6:53 am
PostPosted: Tue Nov 16, 2010 12:24 am
How long do these things last? (The O2 sensors that is)
My check engine light has come on twice in the distant past and each time I did not have a code scanner so I took a shot in the dark and changed out the O2 sensor. Each time the check engine light went off and stayed off so I assumed I had fixed the problem. The last O2 sensor that I replaced is still going with at least 111,000+ miles on it. I don't get any codes from the ECM using the diagnostic port in the fuse block. The only code it kicks out is code 12 - AOK. So I'm assuming the O2 sensor is still good then? BTW, car has 211,000 miles on it.
Thanks!
