It is currently Thu Oct 19, 2017 9:38 pm
 Post subject: 97 Metro Tail Lights
PostPosted: Fri Jan 14, 2011 3:10 am
Are the 4 door tail lamps the same as the 2 door lamps?
I ordered on ebay a right rear tail lamp assembly for my 97 geo.
When the package arrived I was so pleased at the condition of the replacement Light assembly.
The next day I went to install it. Looking at the inside portion of the assembly, the replacement has the lamps staggered in configuration. My tail light assembly has the lamps in a straight horizontal line. The replacement is taller then mine.
Fainya
 Post subject: Re: 97 Metro Tail Lights
PostPosted: Fri Jan 14, 2011 12:12 pm
On '97 Metros "Are the 4 door tail lamps the same as the 2 door lamps?"
No. Not even close.
1998 Chevy Lumina APV
1998 Ford F-150 4X4 XLT
1991 SAAB 900S 5 speed
1987 SAAB 900 Turbo SPG
1985 SAAB 900 Turbo SPG
1974 SAAB Sonett III
1966 SAAB 96
1960 SAAB 93F
1958 SAAB 93B
1964 Willys JEEP CJ-5
PostPosted: Fri Jan 14, 2011 1:51 pm
Anyone got a Right Rear tail lamp assembly for a 97 Metro LSI?
Fainya
PostPosted: Fri Jan 14, 2011 3:49 pm
Probably, post a pic of the front and rear of yours.
PostPosted: Sat Jan 15, 2011 9:17 am
Pictures attached.
img1239 right rear tail light
img1009 front
Fainya
PostPosted: Mon Jan 17, 2011 10:20 pm
any hatchback tail lights will fit from 1995-2001 metro/firefly/swift. sedan lights will not.
PostPosted: Mon Jan 17, 2011 11:44 pm
Headlight bulbs are different for 95 and 96. Ill bet 97 is too. The housings still swap in but you'll need pigtails for the newer bulbs.
Early is h4. Late (98+) is 9007
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Mon Jan 17, 2011 11:51 pm
95 & up will all bolt in. I can find lots. Saw more today. Probably have one on my shelf in a pile of boxes. PM me if yer desperate.
F/S 3Tech economy cam
F/S 90 Metro hatch
F/S 89 Swift GTi body only
F/S 92 Tracker 2 dr rwd stock
PostPosted: Tue Jan 18, 2011 12:57 pm
i have a set of front lights off my 01. let me know if you want them.
