It is currently Sat Oct 21, 2017 2:48 am
PostPosted: Sat Jan 22, 2011 5:06 pm
I am familiar with the MK1 - MK3 Metros, but I have a friend with a 97 Metro, and for the life of me, I cannot find where to disable the ECU so we can set the timing.
I have searched this board, and for what ever reason, I cannot find this little nugget of info. I know it is around here somewhere..
Help?
Thx.
Max.
Current cars :
93 Metro w / 1.0
02 Jetta TDi
98 Blazer 4.3L
69 Camaro w/ I6 250
66 Chevy II 283 V8
52 Hudson Hornet
Miss my 87 Turbo Sprint :( ...BUT :I JUST GOT ANOTHER ONE!!!!! :)
Inliners forever!!
PostPosted: Sat Jan 22, 2011 6:29 pm
the duty check connector is shown in this schematic:
pin 5 on the connector is pin c4 - test switch on the ecu. pin 4 on the connector is chassis ground. jump those 2 connector pins to switch in the test mode for setting base timing.
PostPosted: Sun Mar 06, 2011 5:12 pm
Sorry for the late reply. I got side tracked on some other tasks.
On the Metro, come to find out it is a 99. The ignition jumpers do appear to be different, and according to all data, you jump connectors C and D in a 6 pin plug. On this car, there is a 4 pin plug, and they do show a image of it. However , they are not clear if the C and D wires are consistent in which ones to short out .
Attached are some picts. Can someone confirm that these are still the right wires to short?
Thank You,
Max.
Current cars :
93 Metro w / 1.0
02 Jetta TDi
98 Blazer 4.3L
69 Camaro w/ I6 250
66 Chevy II 283 V8
52 Hudson Hornet
Inliners forever!!
PostPosted: Sun Mar 06, 2011 6:06 pm
Just download this:
http://www.zumodrive.com/share/aPdtNmVlMD
credit to oldman for the answer found in this thread:
viewtopic.php?f=30&t=50347
PostPosted: Sun Mar 06, 2011 8:16 pm
Yup, behind the glovebox on 98+ models...........
http://geometroforum.com/topic/2689420/
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Sun Mar 06, 2011 9:58 pm
THANKS!!!!! :)
Max.
PostPosted: Sun Mar 06, 2011 11:26 pm
maxvamp wrote:
THANKS!!!!! :)
Max.
I take it you never bothered to download the service manual. :oops:
