It is currently Sat Oct 21, 2017 5:14 pm
 Post subject: MK4 POWER STEERING?
PostPosted: Mon Feb 14, 2011 4:05 am
hello, please help me, i have back pain, and now there are arm pain too,
i cant afford the armstrong penalty anymore,,, (steering is very hard and heavy, and i have to drive it 8 hours a day.... )
is there any simple way i can have power steering on my 01 swift (american)
did any model of the american swift ever had power steering? if so, which part will i need and are they direct bolt on ?
and the other question is, will the ECU off a 98 firefly works for a 01 firefly ?
01 is 2 ignition coil and 98 is distributor,,
 Post subject: Re: MK4 POWER STEERING?
PostPosted: Mon Feb 14, 2011 10:25 am
Some 95+ models did come with power steering. Find one and swap rack, hoses, resevoir, pump etc and you are set. Will be a busy days work but not terribly difficult. I may know where you can get the parts, but realize it could be a $400-500 expense to do this project.
I don't think those ecu's will exchange, but I can't say for sure. Why are you switching ecu's around?
PostPosted: Sat Feb 19, 2011 9:59 pm
98 to 01 1.3 liter = DIS
ECU Swap will work.
97 and older = Distirbutor
NO.
01 and older 1.0 liter = Why would you even try? :lol:
My cars:
PostPosted: Sat Feb 19, 2011 10:39 pm
ecu swap may not work. This is due to some years using one coil pack, others using two. I suspect each would use a different ecu.
PostPosted: Sat Feb 19, 2011 10:44 pm
Early 98 uses two packs mounted where the distributor would go.
Late 98 to 01 uses two packs mounted to the valve cover.
Never ever seen one that uses a single 4 pole coil.
My cars:
PostPosted: Sun Feb 20, 2011 12:04 am
Ah, true, I am mistaken. Should be same ecu then indeed
PostPosted: Sun Feb 20, 2011 10:33 am
fyi
i just put PS in my 2000 ..HB usa...everything bolted in
got the parts from a 96 4 door ....easy swap
swift hard to steer...?
jack up the front wheels..and try to turn it. if it takes more then one finger
something is wrong with your car
ECU....no way will that swap work
but i have to ask..WHY...?
PostPosted: Sun Feb 20, 2011 10:34 am
woops ...my bad
the ECU will work
