It is currently Wed Oct 18, 2017 7:30 am
PostPosted: Fri Mar 04, 2011 7:25 pm
Messing around with some before and after testing with seafoam and compression on my G10. The results are as follows:
Before seafoam treatment
110/98/117
After seafoam treatment
110/95/115
Those first two sets I mistakenly ran without wide open throttle. Took new readings with wide open throttle
147/126/155
I don't know what factory specs are, but I know that number 2 is low, so I ran about a cap of oil into cylinder two and tested again. Last reading was about 145. What does that tell me? Are my rings toast? How big of a job is that? Do I get into honing the cylinders and all that jazz? I probably have to pop the head for that too. Any insights would be appreciated.
G10
3 Tech econo head
Suzuki RD header
PostPosted: Fri Mar 04, 2011 8:25 pm
Rings and valves.
Stock is supposed to be around 187psi and no lower than 165psi.
My cars:
PostPosted: Thu Mar 10, 2011 10:03 pm
So are rings doable for someone that is fairly mechanically inclined? I've rebuilt motors before, but usually had the machine work taken care of at a shop. Checked out some videos on YouTube of guys doing some honing and explaining everything. Didn't look to bad. Any tips?
G10
3 Tech econo head
Suzuki RD header
PostPosted: Thu Mar 10, 2011 10:23 pm
Easy job.
Pull the head, drop the pan, and do it in the car.
