It is currently Sun Feb 25, 2018 3:09 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
 Post subject: Re: Rebuilding the 95
PostPosted: Mon May 21, 2012 11:28 pm
I finally figured out what was going on with the rich running! Turns out the vent solonoid next to the vapor canister is plugged when the ecm turns it on. This starts a pressure surge in the tank which eventually shuts off the return fuel line and then dead heads the fuel pump. I had 75 pounds of fuel pressure after 5 minutes of driving!! If you leave the vacuum switch unplugged everything works great! Felt so nice driving it home tonight with no hesitation or jerks when you roll on and off the gas. :buzz: :mrgreen:
Malcolm
'95 Metro 1.0 / 5 spd
165,000 miles
PostPosted: Wed May 23, 2012 8:46 am
That is a fine piece of investigative journalism.
The smog techs in your area deserve a round of applause.
If you fix it, what would happen?
PostPosted: Wed May 23, 2012 10:20 pm
I guess I could do a little more digging and see what's actually wrong with the solonoid? Maybe replace it. I just filled it up today. Hopefully the gauge comes down a lot slower than it has been.
Malcolm
165,000 miles
PostPosted: Thu May 24, 2012 9:53 am
Once you do, you will probably be smarter than 90% of the people in your area who have no clue as to why it should be fixed, eh?
I'm thinking it will cost less than $20.
PostPosted: Thu May 24, 2012 9:38 pm
I've been reading in my FSM and there is a rather complex setup having to do with this valve and the vapor canister. The joke may be on me, the more I read about it the more I'm thinking maybe my gas cap is the problem? By unplugging the VSV I'm keeping the tank from receiving engine vacuum when the ECM turns it on. If my cap isn't venting the excess vacuum it must be what seals off my return line. I'll grab a new cap and plug the valve back in and see what happens?
Malcolm
165,000 miles
PostPosted: Fri May 25, 2012 2:46 am
Believe it or not, testing the gas cap is a part of the California emissions test, and gas caps fail all the time.
PostPosted: Fri May 25, 2012 5:07 pm
I live outside the testing area up here or they probably would have checked mine by now. I got the new cap, now just to drive it home and see if it still runs good? :?
Malcolm
165,000 miles
PostPosted: Fri May 25, 2012 7:45 pm
Well, it made it home ok so maybe the cap was the whole thing all along... :blackeye:
Malcolm
165,000 miles
PostPosted: Fri May 25, 2012 10:33 pm
You have just joined the 10% in your neighborhood who understand the value of an emissions test program.
Congratulations on finding the problem.
Sometimes the easiest fix is the cheapest one.
Happy motoring!
PostPosted: Thu May 31, 2012 11:33 pm
Well, I still have an issue. The gas cap only got me up from 28 to 33 mpg... I'm still noticing a pause in the throttle at 1/2 pedal so I think the fuel pump is still spiking up. I tried unplugging the VSV again and we'll see what that does for the mileage on the next tank. :?
Malcolm
165,000 miles
PostPosted: Fri Jun 22, 2012 11:26 am
Gas mileage has now jumped up to 38.5 so it's getting better. Might be time to try a new O2 sensor.
Malcolm
165,000 miles
