It is currently Fri Feb 23, 2018 5:40 am
PostPosted: Thu Apr 21, 2011 7:45 am
Don't know if this has been done before. I'll reference Suzuk-forums only because the pic file was too large for me to load here.
http://www.suzuki-forums.com/suzuki-swi ... tting.html
PostPosted: Thu Apr 21, 2011 11:29 am
Nice!
Would work for all of the TBI engines as well.
I stuffed an aftermarket pressure regulator to sit between the pump and the throttle body, and it's been serving me well, as being a mount for a pressure gauge. :lol:
My cars:
PostPosted: Thu Apr 21, 2011 12:06 pm
I adapted a filter mounted gauge for a Honda.
Actually, no modification required. It bolts
right on - it replaces the through bolt on the top,
and has a threaded portion for mounting the
gauge on top. I had to lower the filter just a bit
to clear the master cylinder.
PostPosted: Mon May 02, 2011 10:03 am
Well finally got around to testing and the fitting worked well. My fuel pressure tester connects at a right angle so it avoided contact with the PCV hose. If you have a straight connection it might be problematic; probably have to reroute the PVC hose during testing.
