It is currently Fri Oct 20, 2017 6:23 pm
PostPosted: Mon May 23, 2011 9:24 pm
From looking at pics they look the same-ish. Are there any differences, is the cultus intake hole larger ? The MK5 is 45mm wide .
PostPosted: Wed May 25, 2011 12:03 pm
DOHC 16V intakes are not compatible with SOHC 16V intakes. Port size, shape, spacing, and bolt hole locations are all different.
My cars:
PostPosted: Wed May 25, 2011 3:27 pm
Anybody know if the port spacing on the 16v Sohc intake matches the 3 banger?
F/S 3Tech economy cam
F/S 90 Metro hatch
F/S 89 Swift GTi body only
F/S 92 Tracker 2 dr rwd stock
PostPosted: Wed May 25, 2011 7:08 pm
Senior Member
Anyone know the difference between a four cylinder and three cylinder engine?
PostPosted: Wed May 25, 2011 7:49 pm
i think one has 3 sparkplugs and one has 4. not 100% on that but i'm almost positive.
08 Civic Wife's car
PostPosted: Wed May 25, 2011 8:19 pm
not quite right. the difference is one. :-P
mathmatically, difference denotes a subtractive function. =)
PostPosted: Wed May 25, 2011 8:30 pm
sorry mr richard. :lol:
08 Civic Wife's car
