It is currently Tue Oct 17, 2017 12:37 pm
PostPosted: Mon Jun 06, 2011 11:06 pm
I installed p/s from the wreckers and it works as it should. however, it's not as easy as the GMC van that I have driven. is there anything that can be done to improve it ?
PostPosted: Tue Jun 07, 2011 12:34 am
not really. The p/s on these cars add only a small amount of assist. This gives them lots of road feel. In a van you have lots of assist, but zero road feel.
PostPosted: Tue Jun 07, 2011 1:34 am
I guess you cant' have both unless you pay extra for that feature.
PostPosted: Wed Jun 08, 2011 3:34 pm
small update; turns out that i will be returning my 17 wheels to the wreckers, as they have cracks in them.
When I installed the stock wheels, the power steering became way easier. Certainly they designed the system to work with the stock 180/75 wheels.
PostPosted: Wed Jun 08, 2011 10:42 pm
not sure of its the same pump style as the sidekick/tracker ones, (i know its rack/pinion vs box style) but they put a washer in one of the holes where the hose connects, no clue which one. i know it makes more pressure or something along those lines.
if you look around the net you'll find it.
its usefull for running huge wheels on a sammurai/trakick
08 Civic Wife's car
PostPosted: Thu Jun 09, 2011 3:38 am
With 17" wheels you were always going to kill any performance aspirations you had. Suzuki's R and D is great, (except maybe GT gearboxes). The component does the job it's designed for. As Dattman says, "If you want big wheels, buy a tractor"
PostPosted: Thu Jun 09, 2011 10:58 am
Actually if I want big wheels I'l buy 26 inch rims
