It is currently Wed Jan 17, 2018 2:58 pm
PostPosted: Sun Nov 27, 2011 2:23 pm
I just bought this kit off the Bay for my daughter's 2001 Metro 1.3L. I know, it's Chinese cheap parts, but I thought I saw some torque specs and some instruction to torque one of the control arm bolts while it had the car's weight. Does anyone have detailed info for replacing all those parts. EBay kit is here http://www.ebay.com/itm/TIE-ROD-Control-Arm-Suspension-KIT-Geo-METRO-Swift-1998-/330549272035?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4cf6459de3
PostPosted: Mon Nov 28, 2011 3:35 pm
to answer your question directly about the torque, In the first few pages of the service manuel like Haynes will give the torque spec based on the sized of the bolts and nuts. I just finished that exact project on my 89 Geo. Without an extend arm on your wrench, you should be more than enough by tightening them to max you can physically while keeping your thumb over the bolt you are tightening. best of luck
"with these powers, I could be a Super-Hero!"
...name the game and voice actor?
PostPosted: Mon Nov 28, 2011 5:11 pm
Thanks, did you torque one of the ends of control arms with car's weight (or both in the air)? Also, did you have to get the front end aligned after replacing all the parts (I read conflicting reports).
PostPosted: Tue Nov 29, 2011 11:00 am
did everything while in the air. After a bit of driving, you can re-snug the bolts if needed. I havent found it needed it though. As for the allignment. Typically, when a car is correctly alligned and then "falls out" of allignment. It will go back to being correct when the failed components are replaced. Unless you are replacing pieces that adjust the allignment like tie-rods ( I didnt replace the tie-rods on my car), you shouldnt NEED an allignment but if you feel the car pulling or just want to be certain afterwards, go for it. My car pulled wicked and jumped all over the road before I replaced all the suspension components. Once they were installed, it returned back to straight and true for me.
PostPosted: Tue Nov 29, 2011 12:00 pm
Thanks, nix. My kit comes with
2 Lower Control Arms with Ball Joints and Bushings.
2 Inner Tie Rod Ends ( Inner Socket or Rack End ).
2 Outer Tie Rod Ends.
2 Front Sway Bar Links.
I suppose I could just install the Control Arms and sway bar links, but I kind of wanted to shotgun the whole front end. Oh well, I know a place that'll do an alignment for $40.
PostPosted: Tue Nov 29, 2011 1:48 pm
Might as well since it is all there. When you remove the old end links, try to count how many turn or half turns it takes to remove and when you put the new ones on, do that many on the install. It wont be perfect but it will be better than guessing to get you to the allignment shop. Post up your conclusion after your install and allignment! 8)
