It is currently Sat Oct 21, 2017 11:39 am
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: sohc 1.3 8v love
PostPosted: Tue Dec 13, 2011 10:21 am
I just put a mk4 1.3 sohc engine in my 93 metro. I cant find much love for these engines on this forum. Especially for performance. We are limited to the tbi i suppose. But i had some crazy ideas. Im doing a pnp on a sidekick head and fitting it with mikes 395/226.. im also going to turbo this situation. I have been reading up on it and the gm tbi from the smaller 2.8 engines have two injectors the run at 1.5 ohms. Each. If one could do it right make a manifold to support the gm tbi on the g13, i could use a pressure switch to turn the second injector on under boost. one injector can support the car when in hg..
Gimme some feedback
also,
Does anyone know whether the metro injectors are positive or ground fire?
GEO MAFIA!
14 ford Mustang v6.
 Post subject: Re: sohc 1.3 8v love
PostPosted: Tue Dec 13, 2011 11:17 am
I think it would be easier to adapt a gti manifold or better yet, go itb.
99 Honda CB600F Hornet
90 Suzuki Swift 1.6 GLX 4WD
PostPosted: Tue Dec 13, 2011 1:13 pm
That stuff is hard to come by. At least in the states. Gm tbis are everywhere.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Tue Dec 13, 2011 2:56 pm
Use the 1.6 intake and tbi. If I recall, it's 44 mm vs the stock 1.3 tbi at 38
Injectors are triggered by ground. Most Gm 2.5L 4cyls used a single barrel TBI unit that could be adapted quite easily and have adequate flow.
96 Geo Metro 4Dr w/ 98 Swift SOHC 16V & 5spd
PostPosted: Tue Dec 13, 2011 6:09 pm
the tb injector is supplied with battery voltage via the fuel injection relay through a big resistor. the ecu sinks voltage (conducts voltage to ground) through an injector driver transistor located in the ecu.
changing the injector to some other sized injector without the ability to control fuel mapping could be a planned failure. switching in a secondary injector based on charge pressure is a brute force type of control. i set up a hobbs switch to fire the cold start injector on a turbo3 system and ran that way for a while, but again, without some programmable engine management system the afr goes way to the rich side. the secondary injector might keep the piston crowns from getting holes melted in them (for a while) but too much fuel can put the limit on hp as badly as too little fuel.
i'm not saying that you can't do it but you'd have to be really lucky to have the electronic control's slope match the mechanical performance of the larger injectors. chances are that the afr wouldn't be right at any point with the stock ecu. suprf1y's suggestion of the 1.6l injector wouldn't be too far off but i think that the dual injector tbi scheme without proper fuel management, especially in a boosted configuration, is an engine killer.
PostPosted: Tue Dec 13, 2011 9:52 pm
Well originally i was going to use the sidekick tbi. However the fuel injector housing is still a big airflow restriction. It got me thinking so i took a walk in my local junk yard. And the gm tbi is what i came up with.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Wed Dec 14, 2011 8:56 am
You suggest the 1.6 tbi but i just searched for any info on it and found nothing.. I am gonna have to change this.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sun Dec 18, 2011 7:25 pm
I cant find a sidekick wth a complete tb. What is the world coming to
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sat Dec 24, 2011 1:27 pm
Yesterday i picked up some goodies. 1.375" tube for intake runners and 2x4 sq tube for the plenum and tb mount. Also got an exhaust mani fron a newer ford focus to convert to a turbo mani..
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sat Mar 31, 2012 1:25 pm
Finished intake manifold. Just needs paint. Undecided on color.
Hope the pictures work. My apologies in advanced if they dont.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sat Mar 31, 2012 3:21 pm
yep, they work. nice carpet .
PostPosted: Sat Mar 31, 2012 8:30 pm
Awesome. My first successful post with my uploaded pictures. Good faq page.
I picked up a tracker 8valve head. Im going to port match it to the new manifold. And im still searching the best way to port the exhaust. Any advice welcome. Next im making makin exhaust manifold but i need to make trip to parts store to get a gasket to match.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Mon Apr 16, 2012 9:26 am
Update
I was porting the exhaust sunday and found a water jacket. No good. Not sure wat to do. I filled the water jacket with jb weld but not sure what to do. I guess i got too greedy trying to take out a little bit of that sharp turn we all hate. The intake side went well matched the gasket and cleaned th machining edges at valve entry and exit.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Tue Apr 17, 2012 12:26 am
Jb weld on the exhaust side wont last too long, better get it tigged.
I too like the SOHC head but from the vitara g16a as it has bigger inlet valves for starters
also 8 valves is simple on a Gt bottom end should be awesome. g13b bottom ends are
better due to crank and rods and bore it up to 75mm and use vitara pistons also.
PostPosted: Sat Apr 21, 2012 2:47 pm
Alright. Need input. I bought all 8 new stainless valves and not sure if i should lap them and call it good or spend 140 bucks for a valve job...?
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Tue May 08, 2012 9:00 am
Another update. Ive been polishing and unshrouding the combustion chamber. Polished up intake and exhaust runners except bottom of intake was left rough to keep fuel from puddling.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Tue May 08, 2012 8:10 pm
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Wed May 09, 2012 8:28 am
looking the goods! I think g13b rods would be good if not the same
always wanted to know how much hp an 8v head could make boosted and NA
PostPosted: Thu Jun 07, 2012 8:10 pm
Update
edit: Picture fixed.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sat Jun 16, 2012 3:20 pm
Keep it up man. You have such an awesome advantage that you can fab your own everything. Also, take more pictures of EVERYTHING. I love seeing the inventiveness of Swifters and turbo builds. That's how I managed to staple and glue my setup together.
Nick Manning
2006 Scion xB (fun-mobile)
PostPosted: Sun Jun 17, 2012 2:21 pm
Couple goodies. Bov . 44mm tb. Carb hat that will bolt to tb has geo injector housing welded on it.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sun Jun 17, 2012 2:26 pm
Picture of the geo its for as well as my swiff in the backgroung
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Tue Jun 19, 2012 8:30 am
I need specific valve lash clearances for the g13 8 valve. I have mine set now to .008 intake. And .010 exhaust. Measured between lobe and rocker. I just read a couple post that said otherwise. Please enlighten me.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Thu Jun 21, 2012 10:07 pm
looking good! just make sure you have a bracket for the turbo as itll be too heavy not to crack the mani somewhere. interested to see the results as the 8v is underrated!!!
