It is currently Mon Feb 19, 2018 7:06 pm
PostPosted: Thu Mar 29, 2012 3:43 pm
I just bought this Swift,1.3L 5spd, it was not running when I got it but found that the copper wiring in the distributor had come or and was wrapped around the shaft. After replacing the distributor the car started easily but idled a bit rough and Bogg bogs down and backfires at high rpm. I replaced spark plugs, wires, fuel filter, timing belt afterwards just cause I knew it had been sitting for a year or more and while it did seem to improve slightly it still does basically the same thing. I also noticed that my brake pedal is very stiff and does very little to stop the car. I checked the vacuum pressure on it and it flutters around 15psi and jumps to a steady 20 psi under acceleration. It defense like I have a leak somewhere but have checked all over without finding anything. Any ideas or advise would be very helpful. Thanks- Josh
PostPosted: Thu Mar 29, 2012 9:00 pm
I foun the vacume line to the booster was clogged not leaking
Check it out remove hose and try to blow through it.....jv&s
PostPosted: Fri Mar 30, 2012 7:59 pm
when I blow through it I'm met with small initial resistance but then flows freely, I was thinking that perhaps a loss of vacuum pressure somewhere was creating the lack of booster assistance but am not certain that the two are related in anyway.
