It is currently Tue Oct 17, 2017 12:33 pm
 Post subject: GT twin cam motor
PostPosted: Fri Jun 01, 2012 7:05 am
I found a 97 GT twin cam motor. Guy is asking $350. Is this a good price? It is complete and shows no signs of oil leaks.
Fainya
 Post subject: Re: GT twin cam motor
PostPosted: Fri Jun 01, 2012 9:54 am
You might want to check that out I always thought 1994 was last year for twin cam in North America.
Cars and Harleys
PostPosted: Fri Jun 01, 2012 9:56 am
Hot Rod Ray is certainly sober this early in the morning!
Double check the 'letter' following the G13 on the engine block.
http://en.wikipedia.org/wiki/VIN
The letter 'V' is reserved for engines manufactured in '97.
GT's were not imported into the USA after 1994.
They started being imported in 1989, so you might see letters
K, L, M, N, P, R.
If someone is selling a '97 GT twin cam for $350, offer them some 'freshly minted' $3 bills.
At the least, it is a negotiating point - they don't have a clue about the engine.
If you NEED the engine, it is a reasonable price, and seal replacement at this point is a given, so
'not leaking oil' might not be a real selling point either.
PostPosted: Sun Jun 03, 2012 8:24 am
Here is the listing for the motor
http://dallas.craigslist.org/dal/pts/3030446703.html
Fainya
PostPosted: Sun Jun 03, 2012 8:45 am
Thats a toyota engine.
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Sun Jun 03, 2012 10:18 am
geo prix i guess is geo prism
geo prism = toyota corola
08 Civic Wife's car
