It is currently Fri Oct 20, 2017 3:25 pm
 Post subject: ngk-Ridium plugs.
PostPosted: Thu Jul 26, 2012 3:45 pm
well i got a vaca thing coming up so i decided to do some lil things
oil change of course
new air filter :)
and i switch it up with buyin diff. ngk s-plugs and i never use them before
but they are GREAT!!they are way better then the basic ngk plug. i can tell a diffrence:)
2000 metro L"Si":)
2001 suzuki swift
 Post subject: Re: ngk-Ridium plugs.
PostPosted: Thu Jul 26, 2012 5:21 pm
the only way spark plugs can make horsepower is if your old ones are worn to the point of not providing complete spark for adequete combustion. doesnt matter if they are iridium, copper, $17/plug laser platinum, multi electrode, etc.
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Thu Jul 26, 2012 9:27 pm
sweetnlow wrote:
they (ngk-Ridium plugs) are way better then the basic ngk plug. i can tell a diffrence:)
http://www.ngksparkplugs.com/products/s ... ridium.asp
Apparently NGK also "can tell a diffrence". Presumably they have test data to confirm it.
1998 Chevy Lumina APV
1998 Ford F-150 4X4 XLT
1991 SAAB 900S 5 speed
1987 SAAB 900 Turbo SPG
1985 SAAB 900 Turbo SPG
1974 SAAB Sonett III
1966 SAAB 96
1960 SAAB 93F
1958 SAAB 93B
1964 Willys JEEP CJ-5
PostPosted: Thu Jul 26, 2012 10:36 pm
I have a bridge for sale.....
03 cobra bolt ons
PostPosted: Fri Jul 27, 2012 7:21 pm
i'm holding out for swamp land in arizona. :-P
what the iridium plugs are best at is dragging dollars out of your wallet and lasting longer than standard plugs in an oil burner.
the center electrode is really small and set into ceramic. the ceramic center insulator spalls off oil burned to a carbon cinder easier to keep the electrode clean.
any of the high performance g family engines i've built, turbo3 and twincam, have run better with ngk coppers or power groove plugs.
i do keep a set of the iridium plugs on my shelves in case i have to limp an oil burner along until i get around to fixing it. :wink:
PostPosted: Fri Jul 27, 2012 9:54 pm
That is what it looked like....
VR4 wrote:
I have a bridge for sale..... the only way spark plugs can make horsepower is if your old ones are worn to the point of not providing complete spark for adequete combustion.
NGK may be the most respected spark plug maker, sneaking by Champion & Bosch. Want to read what the other makers say about iridium plugs? Or was all their research/data for naught?
Better Google Arizona swamps.
1966 SAAB 96
1960 SAAB 93F
1958 SAAB 93B
PostPosted: Sat Jul 28, 2012 1:34 pm
The point of iridium is making them last. I don't know how many 100hp/cyl engines you've built but I've been thru a fair amount if them. I've tried all 4 major styles of spark plug. Coppers work best but have the shortest lifespan
03 cobra bolt ons
PostPosted: Sat Jul 28, 2012 2:06 pm
My moms 05 RSX Type S HAS to have the OEM iridium plugs or it runs like crap. Even with other brand iridiums and ones that autozone or rockauto list for it made it run terrible. Only the OEM plugs work for that car.
I put NGK iridium plugs on my Sprint along with a MSD Blaster II coil and 8.5mm wires. It made a very noticeable difference in higher rpm smoothness and pull. Not sure if one of those things made the difference or if it was all three. But I do know that stronger more consistant spark will make an engine happy. And a happy engine makes more power. Maybe not seat of pants noticeable and maybe only 1/2hp on the dyno but better is better. Maybe you need the higher output coil and thicker wires for the iridium plugs to make a difference? Also the heat ranges have to be right for your engine. Iridiums may not come in the right heat range for your application. Then there's the plug gap. A few variables come into play here. So maybe they can work great for some while the oem copper plugs are the best match for others. If you don't try, you'll never know. Not too many people here run the exact setup so what worked for my t3 might not work best for t3's t3. My motor build is completely different now so the iridiums might not be the best choice for me anymore. I'll have to play around with plugs, gaps, and heat ranges to find the best match.
PostPosted: Sat Jul 28, 2012 4:27 pm
okayyy soo with all this chater bout them did i was my money on the name or should i just kept my reg.ngk plugs???
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Tue Aug 14, 2012 12:10 pm
Looks like you "should" proof read before submitting post.
Do what you like as far as spark plugs go. You said the iridium plugs "are GREAT!!" & you "can tell a difference" - presumably a positive "difference".
Suspect; performance gain is small, gain in service life is more substantial & benefit in special situations mentioned significant.
1966 SAAB 96
1960 SAAB 93F
1958 SAAB 93B
