It is currently Fri Mar 23, 2018 9:46 am
 Post subject: error code P0450, P1410
PostPosted: Thu Sep 13, 2012 6:26 am
97 geo metro 1.3L, 5speed, federal emissions.
I am getting 2 codes P0450 and P1410 on a cold engine startup in the morning.
Once the car warms up I can clear the codes and they don't come back on for the rest of the day.
I have replacing all the vacuum hoses in the engine compartment for the evaporative emissions system.
All of the engine compartment components tested ok.
From the PCM, testing the circuits show that there is an issue with the tank pressure sensor or the wiring. This means I have to drop the fuel tank.
Not a job I look forward too.
I have never replaced the fuel pump on this car. I also have a fuel level sending unit that show low.
The rubber fuel lines at the tank are original and will be replaced.
Now who do I go to, to get a good fuel pump, sending unit and possible a tank pressure sending unit?
What places should I avoid?
