It is currently Tue Jan 16, 2018 12:24 pm
PostPosted: Fri Dec 07, 2012 3:59 pm
i wanna turbocharge my 2000 chevy metro 1.3l g13b dont want alot of boost to where i have to go standalone fuel managment or increase the injector sizes .looking for something under 10 psi.can it be done ? also how high can the stock internals rev is there a way to increase the rev limiter with an ms6al or is it in the ecm
PostPosted: Fri Dec 07, 2012 5:39 pm
limiter is in the ECM but you really dont want to increase it much anyways. the valvetrain and crank wont really allow much over 7k as it sits.
first thing i would reccomend is a cam. the stock cam in thses is pathetic. if youre dead set on turbo look for a td04 9b (3000gt) or 13g (89-94 dsm auto) both will give decent spool and run 10 psi to redline if you want. the stock actuator spring pressure in the 9b is 6psi and thats about all i would reccomend.
i dont know how the MAP will like the boost (ill be putting a 9b on mine eventually but havent done it yet). you really should look into at least a piggyback fuel computer and some injectors, a wideband, and maybe an ignition piggyback (unless you want to go full standalone.)
its kind of a double edged sword to do fuel mods/piggybacks. larger injectors will need to have airflow pulled out of the signal that will advance timing. you will want to retard timing with added boost.
i have yet to get any info on the flow rates of our stock injectors but i can tell you simply going from 1.3 to 1.6 on mine was enough to trip a lean code with my stock 1.3 injectors.
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Fri Dec 07, 2012 6:18 pm
wow so the injectors are just enough for the engine maybe 10% over .can u tell me about 1.6 swap and how it was acheived.how much faster is it than the 1.3
PostPosted: Fri Dec 07, 2012 9:33 pm
viewtopic.php?f=7&t=51916
In your case i have to recommend getting the 98 non-California exhaust manifold. It might be more difficult to make the one you have work due to the cat
03 cobra bolt ons
PostPosted: Fri Dec 07, 2012 10:31 pm
na i gutted the header cat and main cat custom straight pipe exhaust system that exits where the muffler used to be.cold air intake.was an auto swapped to 3.79 5 speed manual 195/60r15 tires all around exedy clutch kit.it pretty quick for a geo out the hole i want more top end power alot more without spendin to much.i know some cars u can turbo up to 7 psi with changing a thing while others not so much.engine swap is something that im thinking about too which ever can give me more top speed without to much hassle.
PostPosted: Fri Dec 07, 2012 10:39 pm
Mine does right around 120 with the 3.79
03 cobra bolt ons
PostPosted: Fri Dec 07, 2012 10:47 pm
so for a turbo setup id have to get bigger injectors a wideband and apexi safc2 plus turbo kit bare minimum ?
PostPosted: Fri Dec 07, 2012 10:58 pm
maybe ill save my money for the 240sx sitting in the garage.small block lq9 tremec t-56 setup is what im gonna go with lol
[img][http://sphotos-a.xx.fbcdn.net/hphotos-ash4/322742_10150297539591981_2075816839_o.jpg/img]
PostPosted: Fri Dec 07, 2012 11:12 pm
That'll be fun. Honestly the swift is my dd pos beater. I have a couple 3kgt vr4s but right now my money pit is an 03 cobra.
03 cobra bolt ons
PostPosted: Fri Dec 07, 2012 11:23 pm
id love to have a vr4 they are heavy pigs though
PostPosted: Fri Dec 07, 2012 11:47 pm
Funny everyone thinks that.
Not more than a passengers weight heavier than a z32 or supra.
One of mine is down at 2930 all steel and glass. I can still shave about 300lbs off
03 cobra bolt ons
