It is currently Sun Feb 25, 2018 7:16 am
 Post subject: Anyone lifted a 4/5?
PostPosted: Tue Dec 18, 2012 8:02 pm
Was thinking about lifting my 96 up a little. Maybe 1.25 or 1.5 inch and putting a little more aggressive tire on it.
Might be moving farther south to an area with a lot of gravel and dirt roads.
Was thinking if I do this, I could just add a spacer between the strut and the strut mount the same way trucks do the leveling kits.
 Post subject: Re: Anyone lifted a 4/5?
PostPosted: Tue Dec 18, 2012 9:22 pm
Very similar to the black pieces in the front that are made for the SX4.
PostPosted: Wed Dec 19, 2012 1:31 pm
that will probably work in the front but it will screw up geometry of the suspension. for the rear go with sedan springs (might as well go with the sedan rear knuckle/drum too. its bigger)
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Wed Dec 19, 2012 3:15 pm
I though the sedan bolt patterns wre different.
PostPosted: Wed Dec 19, 2012 7:34 pm
its not.
the esteem is different (4x100)
03 cobra bolt ons
PostPosted: Thu Dec 20, 2012 6:35 pm
Thanks. Wish I'd realized that a few years ago when I could have bought some sedan parts dirt cheap off a guy.
For some reason I remembered that Suzuki built the 2dr and Toyota built the sedan. Being different manufacturers I thought they'd be different.
PostPosted: Thu Dec 20, 2012 6:41 pm
suzuki = swift and esteem
toyota = geo prizm = toyota corolla
08 Civic Wife's car
PostPosted: Fri Dec 21, 2012 11:03 pm
Yep thats it. Dont know what I was thinking. :blackeye:
PostPosted: Sat Dec 22, 2012 3:20 am
toyota also built the chevy nova in the 80's. on the corolla platform
PostPosted: Sat Dec 22, 2012 12:13 pm
oh...and in case you havent seen it....
www.teamswift.net/viewtopic.php?f=14&t=54792
03 cobra bolt ons
PostPosted: Sat Dec 22, 2012 11:51 pm
I put 97 sedan springs in my EcoMudder and got 2" lift in front and 2.5" rear.
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Tue Dec 25, 2012 3:04 pm
Thanks VR4 and JohnnyMullet. I had seen the thread before. didn't know you could get that much lift from sedan springs.
