It is currently Sun Feb 25, 2018 7:27 am
PostPosted: Fri Mar 01, 2013 4:55 pm
I have a metro with 345000 miles. The engine has 110000 and a fresh head. Compression is perfect. Car has spark. Has new injector. Has new/junk yard ecu and trottle position sensor. Timing has been triple checked
Car started running a little rough some times and would die some times. It would restart after a while. Now the car will start run very rough then die. When you look in the intake there is a puddle of gas. If i unplug the injector the car will run tell that puddle is gone.
I checked the wire that do derectly to the injector they are fine.
I blew air through the return fuel line, seemed fine.
Pulled a part the pressure regulator on the thottle body, spring and diaphram seemed fine.
Not sure why it is flooding
Any ideas?
Maybe a worn out thottlebody?
PostPosted: Fri Mar 01, 2013 8:50 pm
Check out the ect
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Sat Mar 02, 2013 10:53 am
I had another car with a bad engine coolant tempature sensor. The car still ran but rough. I guess it is worth a check. Any description on where the ect sensor is and how to test it.
Any other ideas welcome
