It is currently Fri Oct 20, 2017 12:39 am
 Post subject: camshaft compatibility
PostPosted: Wed Mar 13, 2013 9:10 am
Anyone know if the camshaft from the distributor drive 16v single overhead cam are the same as the cam from the coil on plug 16v?
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Wed Mar 13, 2013 9:55 am
Other than the trigger wheel on the end for the cmp it pretty much is. I'm not sure if that part can be swapped.
I would honestly have to say no.
Do you need the 98+ cam? They're easy to find down here
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Wed Mar 13, 2013 9:59 am
I have a 2000 swift and want to put in a esteem cam but I can only find the 98 99 ones with distributors still.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Wed Mar 13, 2013 1:59 pm
98 esteem is DIS. 97 was the last of the distributor.
if you find one let me know how it helps. i never bothered to check the difference in lift.
03 cobra bolt ons
PostPosted: Wed Mar 13, 2013 3:12 pm
What is dis? I'm going to PNP after work to look
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Wed Mar 13, 2013 3:51 pm
distributorless ignition system
arlington pick n pull has a 98 esteem
sidekick 1.6 will NOT work.
03 cobra bolt ons
PostPosted: Wed Mar 13, 2013 4:32 pm
that is the one im going to go look at
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Wed Mar 13, 2013 6:25 pm
Lift is the same.
PostPosted: Wed Mar 13, 2013 7:09 pm
It is dis, but not cop. The coils are on the old distributor housing side. I'll get it this weekend if I don't work..
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Wed Mar 13, 2013 10:06 pm
The Swift cop is still a wasted spark dis system. Not true cop
03 cobra bolt ons
PostPosted: Thu Mar 14, 2013 12:41 am
Makes sense. I only had time to take a brief look at it, but I think I found my new tb too!
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Thu Mar 14, 2013 12:47 am
Yup. The esteem is 45mm. First thing i did to both of mine
03 cobra bolt ons
PostPosted: Sun Mar 24, 2013 12:04 am
What are clearances for the valves on these? I know its 6 and 8 for the hemi 2valve heads. And the tb is a nice upgrade. Really helps top end. Now the cam and an exhaust should suit this well. Maybe tranny too
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sun Mar 24, 2013 4:43 am
The 1.6 cam is the same lift, with a very small difference in duration. It's probably not worth all the work to change it. What tranny?
PostPosted: Sun Mar 24, 2013 12:17 pm
I'm aware its not much difference but I want to give it a shot. I'll probably swap a 410 tranny with another metro.
Still looking for valve clearances
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sun Mar 24, 2013 4:24 pm
4.10 is a good choice
Did you search for the lash? I did.
viewtopic.php?f=5&t=37655&p=283650&hilit=16V+sohc+valve+lash#p283650
Also posted it here
viewtopic.php?f=30&t=48005&p=417867#p417867
so it's easier to find
PostPosted: Sun Mar 24, 2013 10:14 pm
I found clearances right after my last post. I got cam in and adjusted. Started it and it fired right up. No butt dyno till I go to work in the morn. Install didn't take me but an hour and a half.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Mon Mar 25, 2013 8:18 am
Butt dyno results:
:thumbsup:
Its worth it for 20 bucks. Its only a small or SMALL difference. If you run accross one at the junkyard, grab it. Then the next day you are bored and have a couple hours, throw it in. I'll say it again, its worth the 20 bucks but that's about it. The can and tb would be nicely complimented with a better flowing exhaust I'm sure. Mine is about to fall in half at resonator and muffler is rusted to hell and probably plugged. But I'm holding out for boost!!
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Thu Mar 28, 2013 2:24 pm
Fwiw I got 46.783 mpg with this setup. Before I averaged 40. No change in course, 45 miles each way 60-70mph occasional unknown high speeds I can't speak of due to passing slow drivers.
GEO MAFIA!
14 ford Mustang v6.
