It is currently Sat Oct 21, 2017 5:15 am
PostPosted: Thu Jun 13, 2013 5:41 pm
hi i have rebuilt my motor when i replace motor in the shell i start but never starting i have no spark a my plug and no fuel but a i have a fuel in my fuel rail help me !!!!
PostPosted: Thu Jun 13, 2013 9:54 pm
Make sure all the ground wires are hooked up. There should be some small ground wires on the back of the intake manifold for the ECU.
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Sat Jun 15, 2013 6:46 am
do you have a picture of ground behind the intake or what is the color of ground
PostPosted: Tue Jun 18, 2013 4:46 pm
PostPosted: Tue Jun 18, 2013 5:40 pm
Not sure if the 4 cyl is the same as a 3 cyl...............
http://geometroforum.com/topic/3563955/
  • Project page
  • Build Video
PostPosted: Tue Jun 18, 2013 8:21 pm
Did you install a pan gasket? If so, remove it and use ultra black or "The Right Stuff" instead. The issue caused by a pan gasket is the crank sensor is too far from the crank to function.
PostPosted: Wed Jun 19, 2013 12:10 am
Already asked that 2 months ago. He claims he removed the gasket.
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Sat Jun 22, 2013 4:16 pm
the motor run !!!!!!!!!!!
