It is currently Thu Jan 18, 2018 3:41 am
PostPosted: Sat Sep 07, 2013 1:35 pm
Ok this car is really hard to start and flooding. It has a new timing belt and I know it is in time. The only clue I have is I am getting code P1510
ECM Back-Up Power Supply Malfunction. How do I fix this? My son really needs his car back and I need his out of the way so I can start working on my truck again. Any help will be greatly appreciated by me and him as well. Ty and have a great day!
PostPosted: Tue Sep 10, 2013 1:13 am
I'll look into this tomorrow but my gut says faulty ecm
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Tue Sep 10, 2013 4:28 pm
pin 14 is white wire on 26 pin PCM connector. fed 12 volts from fuse 23 (15A) in under dash fuse box.
03 cobra bolt ons
PostPosted: Tue Sep 10, 2013 4:40 pm
Apart from the trouble code, take a quick peak at the map sensor and vacuum line going to it. They run horribly and rich if at all if that line gets disconnected or damaged for any reason. It's on the firewall, little sensor with one vac line going to it and one connector. Don't have a pic, but google or a search will clarify I'm sure. It needs to have vacuum to it at all times.
Looks like that code is easy enough to diagnose. It's a simple test to check that circuit. Of course check all fuses, under dash and under hood.
PostPosted: Wed Sep 11, 2013 7:55 pm
Thanks guys will try to get it checked this weekend and let you know.
