It is currently Fri Oct 20, 2017 2:58 pm
PostPosted: Wed Oct 30, 2013 10:59 pm
I have been looking at the many pages for the Suzuki Swift Engine, and I can read that the M13a and M16a engines use the same block.
The engine details are:
M13A
Power 62.5kW
Torque 110Nm
Bore/Stoke 78.0mm/69.5mm
Compression 9.5:1
M16A
Power 76.0kW
Torque 165Nm
Bore/Stoke 78.0mm/83.0mm
Compression 11.1:1
Valve Clearance Same
All the engines have dual overhead cams, 16 valves and are MPFI.
So all i want to know if by changing the crankshaft and the con-rods on my M13a does i get the M16a power ? Do i really need to change my ECU and injectors ?
PostPosted: Thu Oct 31, 2013 1:44 am
These engines are not sold in North America where the majority of forum members reside, the m16 is a taller block, best thing you can do is sell the m13 swift and buy a m15 or a 1.6 sport, I have owned an m13 powered swift and it was painfully slow...save your money and change cars not engines.
