It is currently Fri Jan 19, 2018 2:30 am
PostPosted: Sun May 25, 2014 12:14 pm
Hi guys, Last year the tranny sort of fell out of place and the axel slipped out. The mechanic replaced the axel and the mount. Last week it happended again. I started dismantling and noticed the tranny mount is ok
but I lost the bolt and I do not see a threaded nut welded to the sheetmetal where the mount goes screwed in. Has anybody had this problem before? Can I open access to the sheet metal from the wheelwell and use washers and two nuts to secure the bolt? I would appreciate any suggestion. ( the car had been in an accident before I purchased it so per the diagrams I noticed I am missing a mount cover of some sort.)
PostPosted: Sun May 25, 2014 6:36 pm
on the left side, the big engine mount on the end of the bracket arm has a mount cage that accepts the big bolt that connects the mount to the frame rail. it also has 4 smaller m8 bolts that holds the cage to the frame rail.
on some engine swaps i've done i have used a hole saw to bore an access hole in the outer wall of the frame rail from the wheel well to add a big fender washer and flange nut on the big mount bolt. i located, drilled and tapped the 4 holes for the smaller cage bolts.
i found big electrical punch out caps at the hardware store and selected a hole saw sized to fit those. after i had all the holes for the mount finished i used silicone sealant to cover the access hole to keep splashed water out of the frame rail.
PostPosted: Sun May 25, 2014 9:49 pm
Thanks T3!
I am going to do exactly what you mentioned. I will search the junkyards for the mount cage. Thanks once again.
PostPosted: Mon May 26, 2014 1:13 am
I have drilled all the way through the frame and used a long grade 8 bolt and nut.
PostPosted: Thu Jun 05, 2014 10:15 pm
Nice Job. Thanks for pics.
PostPosted: Mon Nov 10, 2014 4:14 am
Great fix. Have you thought about some eastwoods internal frame spray to keep out the rust?
PostPosted: Mon Nov 10, 2014 11:19 pm
Drilling through is common for auto to stick conversations. Works like a dam.
