It is currently Sat Oct 21, 2017 8:09 pm
 Post subject: j23 swap in 2000 metro
PostPosted: Sun Aug 24, 2014 8:04 pm
has anyone tried this. the j23 is basically same as the j20 and j18 which use the g16b gearbox bolt pattern.if im correct all i would need would be custom motor mounts suzuki esteem driveshafts and jackshaft j23 wiring harness clutch kit for j23 and ecm.
PostPosted: Sun Aug 24, 2014 9:53 pm
Do a search. It's been done, but it's not quite that simple.
PostPosted: Mon Aug 25, 2014 5:37 pm
could u point me in the right direction.so what the not so eaasy part.the cable shifter or does the ecu require some kinda security key ? .ive got a tig stick machine and flux core welder so motor mounts and fabrication isnt to big of a deal.unless we are talking like hub swap or custom driveshafts that has to be made or some kinda precision manufactured piece.ive done a pretty through search and thats how ive come to conclude that it should work with the car just trying to figure everything out before i pull the trigger on getting parts rounded up by next year got 182k on the clock and i put about 30k to 40k a year on it so it wont be long before i will have her worn out.
PostPosted: Mon Aug 25, 2014 6:48 pm
Two second search
viewtopic.php?f=7&t=57385&view=previous
PostPosted: Wed Aug 27, 2014 5:13 pm
looks like i will be pulling the trigger lol.box in the right side frame rail shouldnt be too hard i gotta get in ther and fix the frame horns anyways.ill be sure to load up a new pic heavy post whenever i get to it thatnks for all the help. :twisted:
