It is currently Wed Feb 21, 2018 8:25 pm
Post new topic Reply to topic  [ 155 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Sat Mar 25, 2006 9:47 pm
well here's the latest...
the engine's back in place, but I am definately going to need to build a modified fiberglass hood and find a lower profile bov...
<a href="http://www.teamswift.net/album_page.php?pic_id=7605">Image</a>
<a href="http://www.teamswift.net/album_page.php?pic_id=7606">Image</a>
PostPosted: Sat Mar 25, 2006 9:50 pm
You should take out that crossbar thats in your way.
PostPosted: Sat Mar 25, 2006 9:53 pm
the crossbar isn't even a problem now that it's been trimmed .. it's the height of the intercooler and the plumping running too it .. namely the charge pipe coming right off the turbo and bending towards the intercooler .. the BOV sticks way up as well... might try to locate a stock subbie bov instead of that monster avo sequential unit.
PostPosted: Sun Mar 26, 2006 4:03 am
N1tr0
I've liked the way you have the intercooler
on top dump'in air right down the throat (short run)
It make's a statement
( your driving a powerplant & the body's only purpose is motor mount's with door handles)
I guess that's why alot of coolers or mounted in front
(Hood clearance)
how about drag'in out the Sawsall & Tig welder
for some hack'in-n-patch'in
put the BOV in a down angle
Or patch the hole & move the BOV to the pipe
for some clearance????
PostPosted: Sun Mar 26, 2006 12:44 pm
I came up with an idea .. rally style light pods built into the hood .. that should give me more then enough clearance :lol:
nothing quite this extreme or tall .. but a simple double light hood pod molded in for my hella's ..
http://www.maxitout.tv/albums/tombstonerally/aab.jpg
http://www.roadraceengineering.com/part ... alaser.jpg
it's probably easier to build then explain/photoshop :lol:
PostPosted: Sun Mar 26, 2006 1:09 pm
transition the pods in to a cowl induction.
Its not lag, its suspense...
1987 mk1 T3
PostPosted: Sun Mar 26, 2006 1:24 pm
I'm not sure with the hood so far foward from the windshield that the cowl induction could move enough air to the intercooler .. I want to bring the center section of the hood up a 3-4 inches in the front and taper it back to near flush with the original towards the back with the '04 wrx scoop over the intercooler ...
I'm going to use the light pods to help soften the blunt rise at the nose of the hood there
PostPosted: Sun Mar 26, 2006 1:40 pm
How about something like this (see shitty ms paint picture) dunno how well that'd work but if you put some kind of vent or scoop in the top to draw air in and force it out the cowl? I dunno about the air pressures though... just a brain fart
1987 mk1 T3
PostPosted: Thu Mar 30, 2006 2:11 am
a number of updates over the past few days ...
various stages of mk1 brakes ...
stock mk1 brakes
<a href="http://www.teamswift.net/album_page.php?pic_id=3061">Image</a>
vented mk2 turbo 3/vert/'95+ brake swap
<a href="http://www.teamswift.net/album_page.php?pic_id=3960">Image</a>
and upgraded vented brakes w/ cross-drilled & slotted rotors & ceramic pads from sprintdans group buy, just need to do a full flush with dot5 fluid and find some stainless steel lines to finish it off. :)
<a href="http://www.teamswift.net/album_page.php?pic_id=7683">Image</a><a href="http://www.teamswift.net/album_page.php?pic_id=7685">Image</a>
I also had to clearance the body a bit to hopefully eliminate the rubbing/hitting of the driveshafts against the frame under extreme circumstances ...
<a href="http://www.teamswift.net/album_page.php?pic_id=7684">Image</a>
to help with the fuel requirements for the new turbo setup, I upgraded the fuel pump with a dsm unit, just about any of the in-tank fuel pumps will drop right into the stock location, the one I put in is from a dodge stealth twin turbo and it should be MORE then adequate for the 1L :lol:
<a href="http://www.teamswift.net/album_page.php?pic_id=7686">Image</a>
I also removed the stock fuel sender and installed a universal unit since suzuki was nice enough to use completely oddball resistance values that are totally incompatible with every known aftermarket fuel gauge ....
this way I can wire in an inexpensive vdo gauge, much simpler, much more reliable...
<a href="http://www.teamswift.net/album_page.php?pic_id=7687">Image</a>
PostPosted: Thu Mar 30, 2006 2:30 am
n1tr0 those rotors look sweet
your task seem overwelming
but looks like your very close to finishing it
my hats off to ya
do you know when you will be firing that
motor up ??
would love to hear it maybe make a sound bite
and post it??
-----------------------------------JV&S
PostPosted: Thu Mar 30, 2006 2:34 am
it's all coming down to getting that crank trigger setup finished ... I'm hoping it'll be making noise and smoke within 2 weeks .... but I've been saying that for a long time :lol:
PostPosted: Mon Apr 03, 2006 6:36 pm
One thing n1tro if you could just take her down the track for me atleast once that way I have a idea of what I could have had.
I am trying to sell my sprint but had high goals for it.
I don't want to sell it but you have to do what has to be done sometimes.
My goal is to be in the low 13's
PostPosted: Mon Apr 03, 2006 9:40 pm
it'll be going to the track for sure, at least 1 1/4mile run, but it's really being setup to take to the PCA events, they won't let me race head to head, but I can still participate in the 'drivers ed' events :)
PostPosted: Mon Apr 03, 2006 10:05 pm
Hey Kris
I could be up for that
Think about it
not heads up but
you, jimmy, & I could go there lay downs some base line times
Jiimy's stockers w only cat back Exhaust
mine "El turdbo" mildly mod '3tech cam',Boost control, BOV,
2 1/4 Exhaust, Tires,
your's---- well we all know you'll have the biggest stick on the bock
------------------------------just a thought ???
PostPosted: Mon Apr 03, 2006 11:50 pm
definately :) .. last time jimmy beat me, so I've got a score to settle :lol:
forgot my camera at work tonight, but I've got a whole lot of goodies to sell off to help fund some new tires (and paint & fiberglass) ;)
also at long last, my ignition trigger wheel/pulley is finished and ready to go ... that was pretty much the last part I was waiting for, so a bit more wiring, a bit of fitting, and fabbing up the fiberglass hood and she'll be ready to rock :lol:
PostPosted: Sat Apr 08, 2006 8:36 pm
trigger in and adjusted .. I'll need to shorten the sensor wire a whole lot, not sure if they ever expected it to be mounted to close ;)
PostPosted: Sun Apr 23, 2006 11:15 pm
What's the horsepower do you figure you will get out of your engine? Also does anyone know what the maximum horsepower anyone got out of the 3 cylinder as well as the 4 cylinder?
thank you awesome job on your car by the way
PostPosted: Tue May 16, 2006 11:48 pm
I'm hoping for a solid 200hp, which I'm sure has been done before, eg. the fireandfuel car, but I may be the first one to actually get some dyno printouts .. assuming I ever get it finished :lol:
some more updates .. almost done all the wiring, gauges, & switches, I've got my weatherpack connector pins waiting at napa and the seats & dash ready to be bolted in place ...
pictures is a bit dark..
PostPosted: Tue May 30, 2006 4:45 pm
Hi Kris,
This rotar you got, what diameter is it?
I have now fitted mk2 Gti discs(250mm) which turn it down to 240mm with mk2 caliper.
I works but I think there might be little air in it......
Feels bit spongy at the time.......knocking on deaths' door!?
Cheers
Atchi
PostPosted: Fri Jun 16, 2006 1:20 am
couple teasers ...
all done wiring up the car .. completely .. gotta go around & check my grounds, bolt in the dash, calibrate the wideband, and see if it starts .....
and I need to relocate the bov from the wrx intercooler, it was that or make an even larger bulge in the hood ... managed to get the intercooler another inch+ lower then before and shortened the turbo piping a hair so the hood closes like this ...
nothing but intercooler through the scoop
PostPosted: Fri Jun 16, 2006 1:31 am
fireing it up saturday in front of an audience??? :D
Dattman wrote:
PostPosted: Fri Jun 16, 2006 1:43 am
if it fires up tomorrow night, I'll start it again saturday, but I'm not going to dick around with it during the open house if it's not running yet ...
PostPosted: Fri Jun 16, 2006 3:59 am
where did you get the adjustable cam timing pulley from and what was the
price :?: :?: :?:
PostPosted: Sat Jun 17, 2006 10:11 pm
sweeeeeeeeeettttt,, wamm-puchsss man i would love to hear that thing run,maby even pay some cash haha.nice hood lookin good let me no if you ever wanna sell it,even thou i know you dont,cause you got so much time in it. :wink:
PostPosted: Sun Jun 18, 2006 11:11 pm
almost everythings for sale if you have enough $$$ :lol:
my list of things to have it on the road has gotten a lot shorter ...
[list=]relocate bov from intercooler to piping so the hood can close
find a way to clamp the filter adapter to the turbo neck
bolt the seats down
bolt the dash in place
finish/primer/paint the hood
fit the hood locks
[/list]
