It is currently Sat Jan 20, 2018 7:49 am
 Post subject: MK1 Dash Board Question
PostPosted: Sun Jul 01, 2007 2:27 am
Does anyone here know how to remove the dash pad on my 88 Sprint Turbo? I want to replace it and not ruin it either!!!.
thanks
PostPosted: Sun Jul 01, 2007 4:45 am
Senior Member
If you mean the soft upper... its glued on.....
PostPosted: Sun Jul 01, 2007 7:22 am
the soft part is not glued, its stuck up and saved with clips from behind. so you must take the hohle dashboard out...
by
That's 30 minutes away? I'm there in 10!
------> http://www.cardomain.com/ride/2496630 <------
------> http://www.youtube.com/results?search_q ... rch=Search <------
PostPosted: Sun Jul 01, 2007 2:03 pm
Senior Member
bugger me, mines glued! and clipped.... must be the difference between a barina gti and a swift gti....
