It is currently Thu Oct 19, 2017 11:29 pm
Post new topic Reply to topic  [ 22 posts ]
PostPosted: Sat Oct 07, 2006 2:29 am
These are miscellanious scans from the Suzuki SA310 factory service manual. The information here should apply to most MK1 Sprints, Fireflies, Forsas and SA310s (exceptions apply).
Periodic Maintenance 0B-3 (alternator/water pump belt tension, valve lash adjustment* )
image_id: 9822
Periodic Maintenance 0B-6 (spark plug gap* and ignition wire check)
image_id: 9823
Manual Rack and Pinion 3B1-13 (torque specs for steering rack and tie rod components)
image_id: 9824
Front Suspension 3C-9 (front brake exploded diagram, wheel stud installation, torque specs)
image_id: 9825
Front Suspension 3C-15 (front suspension torque specs)
image_id: 9826
Rear Suspension 3D-12 (rear suspension torque specs**)
image_id: 9827
Engine Mechanical 6A-12 (lower transmission brace, engine mount exploded diagram and torque specs)
image_id: 9828
Engine Emissions Controls 6E1-24 (ECU diagnostic codes***)
image_id: 9829
* does not apply to turbo models
** does not apply to '85 - '86 models with leaf springs
*** only applies to '87 - '88 models with ECU controlled feedback carb
This is the whole chapter on heater and ventilation service. This only applies to '87 - '88 vehicles with the updated dashboard.
Heater And Ventilation 1A-2 (exploded diagram)
image_id: 9830
Heater And Ventilation 1A-3 (system operation)
image_id: 9831
Heater And Ventilation 1A-4 (diagnosis, blower motor service)
image_id: 9832
Heater And Ventilation 1A-5 (blower motor resistor check, speed switch diagram)
image_id: 9833
Wiring Diagrams
Full vehicle wiring diagrams. Note: almost every different MK1 seems to have it's own wiring diagram depending on engine, transmission and even model year. Wiring diagrams are only considered accurate for the exact models listed below:
1988 carb'd 3 cylinder, manual transmission:
click for full image (4824 x 1564 PNG 640 KB)
Body Dimensions are here:
http://www.teamswift.net/viewtopic.php?t=15167
Transmission servicing is here:
http://www.teamswift.net/viewtopic.php?t=26290
Scans from my Haynes repair manual:
Diagnostic switch location on 1987 - 1988 models:
image_id: 3963
General wiring diagram:
image_id: 6186
PostPosted: Wed Jan 14, 2009 3:43 pm
hi..... pls i need help, i dont know how to conect the ECU in my car...
somebody can send me a wiring diagram of ECU EPI-001 suzuki swift mk1 1.3 DOHC
thanks :?: :vibe:
PostPosted: Tue Aug 25, 2009 2:28 pm
I clicked on the images, but nothing happened. I would like to see that big wiring diagram.
Thanks, SA
PostPosted: Mon Aug 31, 2009 2:51 am
those images are pretty useless; too small to see. can you make them bigger?
PostPosted: Mon Aug 31, 2009 10:59 am
Those used to be clickable thumbnails.
They were shortcuts to the gallery section on MK1's Factory Service Manual Scans and other member's pictures.
The links were messed up in the last server move, but all the pictures and more are available here:
gallery/album.php?album_id=5
and here:
gallery/album.php?album_id=1
As of this post, that's over 44 pages of information, from engine to transaxle.
Hope this helps.
PostPosted: Sat Sep 05, 2009 8:57 pm
They way the links were formatted under the old forum software were broken during the last upgrade. I've just updated all the links, so everything should work again. The small images are actually thumbnails, and you can now click on them to see the full sized image.
PostPosted: Mon Aug 02, 2010 11:48 pm
Please upload the complete FSM of MK1 as a single file (like PDF)
PostPosted: Tue Aug 03, 2010 2:36 am
It's here:
http://swift.hit.bg/3EN.html
PostPosted: Fri Nov 05, 2010 5:58 pm
Phil N Ed wrote:
It's here:
Hi, any chance I could get a new link for this? Thanks!
PostPosted: Thu Nov 18, 2010 12:08 pm
hey..can u guys post that pdf in a new link? the old one's not working...
PostPosted: Sun Feb 27, 2011 5:05 pm
Sprint has the diagram of motor 1,0 3cl
PostPosted: Wed Apr 03, 2013 9:20 pm
here's the link for the Chevy Sprint A/C Removal thread
http://teamswift.net/viewtopic.php?f=31&t=46740
1986 Sprint Air Conditioning Supplement
ftp://ftp.sonic.net/pub/users/bjcorr/Sp ... iceMan.pdf
.jv&s
t3 ragtop wrote:
suprf1y wrote:
jrjd wrote:
PostPosted: Thu Aug 22, 2013 10:27 pm
Does anyone have a pdf of the FSM all the links above don't seem to work.
Thank
Dan
PostPosted: Thu Aug 22, 2013 10:56 pm
TT
Last edited by jaguar,vettes&sprints on Fri Aug 23, 2013 10:12 am, edited 1 time in total.
PostPosted: Fri Aug 23, 2013 12:20 am
who M' I kiding
PostPosted: Sat Aug 24, 2013 1:49 am
Thank
Dan
I fixed the links a long time ago, however some of the files are no longer on the new server. I still do have files, but all my MK1 tech docs total to 181 megs. I'm on limited bandwidth, but if you send me a SASE with blank media of your choice, I can mail it back to you with the files on it. PM me for my shipping info.
PostPosted: Sun Aug 25, 2013 2:06 am
@ssclown
Hi Lihtan, so glad to learn you're still driving a Suzuki, we seem to be a dwindling crowd.
Thank you very much for posting those FSM links and then fixing the ones you could after they broke. I'm trying to fix the ECU and MCS carburetor wiring on a 1988 Forsa w. 5spd. manual trans that I just bought and I got to the point where I needed a wiring diagram, and since mine was rendered unreadable by rats munching on it, I was dead in the water for about a week until I discovered the Mk1 wiring diagram you had posted in this thread. I'd missed it before because I thought the links to the diagrams were broken, but I just happened across it a few days ago as I was aimlessly surfing through teamswift threads wondering how to fix my car.
I want to buy a USB memory stick, or thumb drive, or whatever they're called, and get it to over to you for you to download the rest of the Mk1 FSM onto it if you could, but how many Giga Bytes should the memory stick be? I'm guessing even just one GB should be enough so any memory stick with more capacity than that would suffice but before I acquire one I thought I should ask you what size is sufficient. I'll send you a PM with some contact info for me on it and I'll also be quite happy to shoot you twenty bucks or whatever for downloading the FSM onto a USB stick for me because that's what anyone on Craigslist is asking for FSMs they've downloaded on to CDs.
PostPosted: Sun Jan 25, 2015 11:33 am
If you guys have the mk1 service manual 99500-82600 or 82601 I would greatly appreciate it if you could upload it and send me a link. I have the supplement for the Gti but not he whole manual and i need it to restore my 86' mk1 gti.
Thanks
G13B 1.3L 16v 115hp
PostPosted: Tue May 05, 2015 11:01 am
Please could send me to send my mail cheo.e.calderon@gmail.com
PostPosted: Sat Sep 12, 2015 4:05 am
How's your bandwidth now? I could provide a host for those files if necessary. I would greatly appreciate if someone could provide me the service manual as well :)
PostPosted: Sat Feb 06, 2016 6:06 pm
YES PLEASE - a link to ANY MK1 FSM's would, of course, be incredibly appreciated by so many of us.
in any event - thanks!
/feb.2016
PostPosted: Thu Aug 03, 2017 7:26 am
Devon & Jones Quarter-zip DG440
