It is currently Fri Oct 20, 2017 6:24 pm
PostPosted: Tue Sep 14, 2004 2:13 am
Does anyone know where I can find a crankshaft seal for this car??? I checked autozone and its discontinued :x
PostPosted: Sat Sep 18, 2004 12:42 pm
Pull the seal off the car and take it to a place that deals with bearings (like ball bearings) and stuff. They usually carry seals as well. Since the crank seal for your car is just a basic press-in oil seal, they can take the dimensions off the face of the seal (try not to wreck that when prying the seal out) and get you one. It'll probably end up costing you less than what it would have at autozone, too.
91 Sprint, 5 spd, 12* advance timing, 10* avd. cam gear,
3Tech MPG Head package, 9mm plug wires, 3Tech underdrive
PostPosted: Wed Oct 06, 2004 4:55 pm
It is the same as the cam seal - You can also cross it to any 1.0L metros, flys, etc - My `91 head takes the same seal as my `88 block
Cheers
Adam
91 Geo Metro LSi-t Convertible
Turbo enhancement
97 Dodge Neon
2.4L turbo 13.165@107.41 8psi
