It is currently Sun Feb 18, 2018 6:05 am
PostPosted: Sat Oct 30, 2004 8:48 pm
i'm hoping that you t3 gurus can give me some insight into where i should start to track down a problem.
the engine starts and runs for 15 to 30 seconds at about 2500 rpm, then acts like it runs out of fuel and dies. if i feather the throttle, i can get the engine to keep from stalling out and the revs bounce back up to 2500 rpm, then fall, and the engine will die if i don't open the throttle again. the engine will start up and run pretty strong initially. when i start to feather the throttle, it misses and spits and generally runs like crap.
i pulled the cap off of the MAF so that i could see what it does and the rheostat wiper moves to different points depending on throttle angle and air flow. there is a pointy actuator that looks like it should open some contacts, but the end is bent so that even with the flap closed all the way, it doesn't touch the contacts.
i though that it might be related to low fuel pressure so i swapped the NA fuel pump out with a new turbo pump which really didn't change the condition much. is this a TPS induced condition? and MAF induced condition? crappy fuel injectors? ECU?
i'm baffled and have no manual for troubleshooting. please help.
PostPosted: Sun Oct 31, 2004 11:36 pm
CJDave, jardamuth, suprfly - calling all turbo3 wizards! :worship:
HELP! :thwack:
PostPosted: Mon Nov 08, 2004 4:46 pm
update.....
i checked and re-checked:
the fuel pump for delivery and pressure - ok.
ignition for spark - ok.
maf for operation - ok.
engine bay harness connectors and various sending units, including water temps. valve controls, TPS -ok.
i listened to the injectors with a really long screwdriver in place of a stethescope and they stop firing after 30 seconds like clockwork. something is telling the ecu to cut fuel, hard to believe because the engine only just fires up with the fuel enrichment injector banging away. as soon as the cold start enrichment ceases the main injectors quit, too.
i've studied the supplement and it gives a set of things to look at but they all seem to be ok, too. the finger is pointing at the ecu not being a happy 8 bit camper.
any thoughts from great minds? :lol:
PostPosted: Tue Nov 09, 2004 7:41 am
I came across a post somewhere about a problem similar to this - I think the guy said he forgot to ground the main fuel injector return and everytime the cold start injector was switched out, all the injectors would shut down.
I have no idea what I'm talking about here, just repeating what I read - hope it helps
PostPosted: Tue Nov 09, 2004 12:13 pm
thanks fordem
that's what i thought, too, so i checked that. the injector ground wire is securely fastened to the intake manifold.
in reading the turbo3 supplement i've found that there is a provision for fuel cut when the ecu isn't happy about something, however, it isn't clear what would piss it off that bad.
thanks for taking the time to consider my problem and responding.
PostPosted: Tue Nov 09, 2004 1:11 pm
a.k.a Bum head
I'm still gonna point to the MAF. That's about the only thing that you just can't check with reference to what it's supposed to do... any codes stored at all?
I feel for ya... I had my conversion sitting in the garage for about 3 months until I finally got it to fire up. I don't wish that on anyone.
Chris
Good stuff for sale!
PostPosted: Tue Nov 09, 2004 1:20 pm
a.k.a Bum head
Also... do I remember you telling me about using a different dizzy than what's stock? I seem to recall something about vacuum advance... which there shouldn't be at all. There's only the distributor pick up sensor, and that should be it attached/coming out of/going into the Mk2 T3 dizzy (besides the spark plug wires).
Chris
PostPosted: Tue Nov 09, 2004 3:48 pm
nope, no stored codes in the ecu. it winks a happy 12. the distributor is the non-vacuum advance unit that was standard after 92 and is the same as the turbo engine unit (2 wires to give the ecu the crank position.)
it wants to run. :lol:
PostPosted: Tue Nov 09, 2004 4:36 pm
there's no difference in the pin-out @ the ecu for the injector harness or something eh ? even with a dead maf it should still idle in limp mode if it's anything like the gt
PostPosted: Tue Nov 09, 2004 5:16 pm
a.k.a Bum head
I tried that when I was having problems with my swap, I would get an overboost code when the wrong MAF was plugged in, and the car wouldn't even run without it plugged in. No limp mode... :?
Chris
PostPosted: Wed Nov 10, 2004 4:03 am
chris,
when you got the overboost code, did you get a fuel cut that caused the car to quit? that's one of the conditions that the supplement shows as a "no start" or fuel cut condition. i remember that you said that you didn't know that you had the wrong MAF on your car because they look the same. the wiring splice of the mk2 to the mk3 means that the nifty little diagnostic switch on the mk2 isn't there and i have to plug a fuse into the fuse block "test" position to get the check engine light to wink (but it does.)
the parts car i got my parts from might have been junked for the very reason i'm snatching myself bald right now. the previous owner may have used the wrong MAF, the ecu could have been toasted, etc, which caused the car to be junked in the first place.
i'm very disheartened.
PostPosted: Wed Nov 10, 2004 4:41 am
I would say, as youve predicted, that the ecu is at fault. Id offer mine, to swap and check, but its mk1. Sorry I couldnt be of more help.
Nick
PostPosted: Wed Nov 10, 2004 3:16 pm
a.k.a Bum head
chris,
The car would run, but be waaaaay rich, blowing black smoke, making the exhaust manifold glow red/white and spooling up the turbo from the heat of the ignition of unburnt gas, until it warmed up (and got off the open-loop mode). Then it would shut down until it cooled down again. It would run for about 5 mins. since it was about -10C when I'd finished the transplant. I bet your car wouldn't run as long, since it's warmer now.
Don't lose hope... really. I'm pretty sure that your ECU is fine, there's just something pissing it off. I'm willing to bet my MAF that it's your MAF that's messing things up. Getting an Mk2 MAF is about as easy as finding hen's teeth... I'll have to check through my old e-mails to see where I sourced mine from last summer, since I think they may have one still. Might even have been Jard... I'll get back to you on this.
Hold on there!
Chris
PostPosted: Wed Nov 10, 2004 3:58 pm
found a few wreckers in canada w/ turbo firefly/sprint engines that might have the maf ...
1-800-528-1483 - http://trade2883.car-part.com/
1-800-463-5158 - http://www.pintendre.com/
PostPosted: Wed Nov 10, 2004 4:34 pm
Mama Said Knock You Out!
My 94' Concorde did the exact same thing. But it would only run for 5 seconds, and it would shut off the fuel. It ended up being a bad injector resistor. I dunno if the T3 uses an injector resistor though.
TGstring wrote:
sooooo clean it's duuuuurrty.
PostPosted: Wed Nov 10, 2004 6:18 pm
a.k.a Bum head
Nope. No resistor to be found (unless it's in the ECU).
Chris
PostPosted: Wed Nov 10, 2004 6:23 pm
a.k.a Bum head
And indeed it was Jard (Jess) that found my MAF back in May 2003. Perhaps he's been trolling this thread and wouldn't mind letting you know if he has any other MAFs floating around, even after almost a year and a half.
Chris
