It is currently Fri Oct 20, 2017 12:39 am
Post new topic Reply to topic  [ 77 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Nov 18, 2005 9:57 pm
It could easily be split up into little parts, so you could download a bit whenever your on. Then, once its all done you can extract it and view it. lol...
PostPosted: Sun Dec 03, 2006 11:51 pm
I seem to remember this sup manual is available in the Vancouver public Library Reference section. If some has a dig camera or is in need of looking.
I used the ref back in 95 should still be there if some has not scooped it.
PostPosted: Sat May 03, 2008 11:00 pm
Hi Guys, I have tried every link to the manual and they all come up to a google page that says, "oops this link is broken". Am I doing something wrong? It would be great to have this manual, thanks to all who have put so much work into it.
PostPosted: Sat May 03, 2008 11:07 pm
The Smuggler
seems with the site move to another server a lot of old links don't work.
will contact the admin and see if it can be fixed, otherwise I have in downloaded on my computer and if there is a particular part you are looking for let me know and I will see what I can send you in PDF.
the manual is for the MK2 89-91 Canadian Turbo model.
And I love this one!
 Post subject: Re:
PostPosted: Sun Oct 26, 2008 9:09 am
a.k.a Bum head
Edit: Replaced the original TeamSwift link with a torrent link. See my next post below. Please seed.
PostPosted: Sun Oct 26, 2008 9:22 am
a.k.a Bum head
I've also created a torrent. Click on the link below to start the download (with the appropriate Torrent client, like uTorrent).
CLICK HERE
Please continue to seed after you're done downloading for the benefit of your friends here on TeamSwift.
edit: Link should be fixed...
Good stuff for sale!
PostPosted: Sun Aug 09, 2009 1:04 am
The link... it is broken...
My cars:
PostPosted: Sun Aug 09, 2009 8:52 am
a.k.a Bum head
WTF?!?
Alright. I'll fix it.
edit: Fixed. The above link should now work. Not sure what happened to break it, but it works again.
PostPosted: Sun Aug 09, 2009 10:28 am
Old Link: http:__www.execulink.com/~crdreyer/downloads/t3supplement.zip.torrent
New Link: http:__www.execulink.com/~crdreyer/download/t3supplement.torrent
I'm guessing the downloads folder went missing.
Thanks for fixing it! :D
My cars:
PostPosted: Sun Aug 09, 2009 10:33 am
Works!, I'm seeding also as we speak. Thanks alot, a great reference to have :)
-Save the Trees, Eat a Beaver!-
91' Firefly Turbo Convertible -> '90 G10T Swap, +6 Timing Sprocket, Stock Turbo, intercooler & 198/330 Cam, NGK V-power's, 7mm wires, Boost Gauge, Manual Boost Controller set to 9psi, Mobil 1 & GM Synchromesh, Short Shifter, K&N + removed resonator, Gutted Pre-cat, 2" Exhaust, High Flow Cat & Muffler, Front sway bar, Front underbody Brace, 185/65R14's on Steelies..
PostPosted: Tue Aug 11, 2009 1:22 am
Link worked properly !
I'll try to get the Book I Used when I Redone my Motor, the book is staying in the rack's taking the dirt and there's a Part's list Book for Sprint,Firefly & Metro 89-94 too ! I'll ask my Buddy's Father if I Can have it, he's working at a GM Dealer where I got the T3 Supplement from ! I'll try to buy them ! :mrgreen: And I'll be able to give you all the Part's number you need the Book is thick lol !
G-Spot
Mk3 Geo Metro W/ Mk2 G10T
PostPosted: Tue Aug 11, 2009 6:21 pm
a.k.a Bum head
Too bad the majority of those parts are no longer available considering that both the Mk1 and Mk2 turbo cars are older than GM will stock parts for.
PostPosted: Wed Jan 13, 2010 2:17 am
sorry, but is there a mk2 t3 manual available online?
PostPosted: Wed Jan 13, 2010 7:20 am
a.k.a Bum head
Edit: Changed all links to reference the Demonoid link, where it's living right now. You might need to sign up to Demonoid, but it's an excellent torrent tracker and well worth subscribing to.
PostPosted: Wed Jan 13, 2010 10:24 am
i have turbo manual,as well as non-turbo,as well as 1987 sprint manual,let me know if you need any certian pages,4 books in total,they are in rough shape,all pages are there. after 10 years,gm considers a vehicle discontinued,although they still have some parts kicking around :-P mk 2 manual
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Wed Jan 13, 2010 10:37 am
a.k.a Bum head
Working on relisting the torrent today. For some reason I can't find it listed on any index sites. Gonna reupload the torrent file to Demonoid, so hopefully it'll have better availability.
edit: Seeded on Demonoid and a couple other tracker sites.
PostPosted: Thu Jan 14, 2010 3:14 pm
do you have a link to the torrent? I tried searching demonoid but nothing. Cheers!
PostPosted: Thu Jan 14, 2010 3:18 pm
a.k.a Bum head
You don't need to search. The link is in my last post.
PostPosted: Thu Feb 18, 2010 2:00 pm
ok, whitch link do i go to get the MK2 supplement? and also is there any viruses from downloading? i don't trust downloading stuff.
Thank you!
i want another metro!!!!! LOL!
PostPosted: Thu Feb 18, 2010 8:46 pm
a.k.a Bum head
The most recent link will take you to the Demonoid site, where you'll find the torrent file. You won't find any virii in the file that downloads. I'll have to edit my old posts and remove the confusing references that might make it hard to get the supplement.
PostPosted: Thu Feb 18, 2010 8:57 pm
oh ok, well i already have the MK1 supplement. i wanted the MK2 too, but i don't think i'm getting it. i am not registering just to download a file, ugh. not only that, but that site is filled with ads and crap, :evil: yuck. oh well, i guess, i'll just live without it. i wish it was on PDF file like the MK1 supplement is, but i understand its to big to do that, oh well.
PostPosted: Thu Feb 18, 2010 11:20 pm
a.k.a Bum head
Crap. I didn't realize that Demonoid needed a registration for older torrents. I use it all the time for stuff, so I already have a membership. Anyone know of a free tracker where I can toss up the torrent file? Can we still use the TeamSwift server?
PostPosted: Thu Feb 18, 2010 11:45 pm
oh ok, well i didn't mean to sound rude, i wasn't tring too. but yeah, i honestly don't see a point on joining just to download 1 file. um....dang its to big for email? ugh.
well, i'll keep my eye out here for more info about the file. thank you very much!
PostPosted: Fri Feb 19, 2010 11:38 pm
a.k.a Bum head
It's a 20Mb file. Far too big to be sending over e-mail as far as I'm concerned. I may eventually get a server of my own started up to host the .torrent file (as well as other stuff non-T3 related), but don't count on that any time soon. For now you either need to sign up on Demonoid or hope that your favourite torrent search site has referenced the file. I'm surprised you can't find it on IsoHunt since it's a fairly powerful search site for torrents.
PostPosted: Fri Feb 19, 2010 11:44 pm
oh ok. well....honestly i don't download things, or at least i try not to.
