It is currently Wed Jan 17, 2018 2:31 am
PostPosted: Tue Jan 04, 2005 9:21 pm
This past weekend while putting mk2 gti seats in my mk1 I snagged my friends blow off valve so I could turn up the boost a little more and not shim the pressure relief valve on the intercooler. Anyway, I was coming home from work yesterday and the timing belt broke. I walked home got my SLK, went bought a new belt and put it on so I could drive to work today. After I got it running I noticed the BOV sounded different (stronger/more air flow??) and "maybe" the car runs a little stronger. My question is...... Is it possible that the timing was a tooth off or something before (I changed head gasket a few months ago)? Any ideas?
Sorry so long.
Thanks,
Andy
PostPosted: Tue Jan 04, 2005 10:11 pm
a.k.a Bum head
That's completely possible. You also might've moved the timing up a notch farther on your new install... how many degrees is a notch? I've misplaced the number...
Chris
Good stuff for sale!
PostPosted: Wed Jan 05, 2005 8:47 pm
i think 1 tooth on the cam timing gear equals about 6 degrees. if it was down 1 tooth it makes the engine dog pretty badly. if it's up one tooth from normal and you don't change the spark timing, it makes the engine seem to have had a super tune-up.
PostPosted: Wed Jan 05, 2005 9:12 pm
Thanks for the replies guys. It ran pretty well before but didnt seem to pull as hard as it did when I test drove it or since the belt broke. I was hoping to find this possible, my friend said "no way, it wouldnt run".
PostPosted: Wed Jan 05, 2005 9:15 pm
a.k.a Bum head
Good thing G10 engines are non-interference engines. You could crank the cam timing 120* out of sync and not trash anything. :)
Not that you'd want to, but it's a nice safety cushion for n00bs. (Not saying that anyone here is...) :lol:
Chris
PostPosted: Wed Jan 05, 2005 11:23 pm
Chris
Yeah, been there done that. 1991 VW GTI 16valve snapped the timing belt on the racetrack :( Bent all 8 intake valves (2 more then the g10 has :) ). I was thinking all this while walking home to get the new belt. Even came home and did a search on "interference" to make sure I was right about it not being such a motor ( yeah I know, most if not all turbo cars are non-interference).
Thanks again,
Andy
PostPosted: Wed Jan 05, 2005 11:29 pm
a.k.a Bum head
And then if you have suprf1y's timing advance cam (mine's a 6* advance), a tooth back will almost run normally, a tooth forward will ping like crazy at idle (I'm suprised I didn't burn a valve).
Chris
