It is currently Fri Oct 20, 2017 2:47 am
PostPosted: Thu Mar 02, 2006 3:21 am
'87 - '88 turbo 3 engine codes:
12 normal
13 o2 sensor
14 coolant temp sensor (open circuit)
15 coolant temp sensor (short circuit)
21 TPS (open circuit)
22 TPS (short circuit)
23 intake air temp sensor (open circuit)
25 intake air temp sensor (short circuit)
31 abnormally high turbocharger pressure
33 AFM (open or short circuit)
41 ignition signal (no signal from ignition coil for 2 seconds with engine starter switch turned on)
____steady____ ECM failure
i searched a while to find these so i figured i would post them up.
Dattman wrote:
PostPosted: Thu Mar 02, 2006 12:27 pm
I thought I posted a scan of the manual page...
PostPosted: Thu Mar 02, 2006 12:46 pm
i didnt find it while searching. all i found was this list you posted a while back.
PostPosted: Sat Mar 04, 2006 1:33 am
thank's tuffcarguy for the ECM codes
you guys are making it to easy
pretty soon i'll just dump my manuals
just print out what i need then take it out to the "Hoopty"
don't have to worry about smugging the book
Karma (ya like you need it)
PostPosted: Thu May 18, 2006 9:15 pm
http://home.flash.net/~lorint/lorin/fuel/enginecode.htm
