It is currently Sat Jan 20, 2018 8:53 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2  Next
PostPosted: Wed Sep 03, 2008 3:02 am
Hello
I have come across a g10a 3 cyl engine with the turbo but it is not efi . The engine was pulled out of the car by someone else and I have a cut loom and a box full of bits .
Can anyone point me in the right direction to get some info to help me get it up and running ?
The engine number is G10-149553 , can anyone date the engine from this ? It has a knock control box and a control module and a Vacuum switch unit that all need to be wired in . Then I need to start on the maze of air control valves and the associated manifold plumbing . Hope to get it sorted and put in into a suzuki LJ 4x4 .
Issues at the moment are wiring and also cam timing , I think its 90 deg out :( . Are these an interferance fit motor , might be pulling it apart earlier than planned .
If it all gets to hard maybe I put aftermarket efi on it .
Thanks
Chris
PostPosted: Wed Sep 03, 2008 7:26 am
a.k.a Bum head
YAY! Something "new" in the turbo G10 world. Looks interesting... weird intake manifold, but interesting nonetheless.
More pictures required. ;)
The G10 is a non-interference engine. There shouldn't be any damage to the valves if the cam and crank disassociate. :D
There shouldn't be much to wire on this engine, since it's non-efi. Doesn't mean that there isn't still a whole pile of little things to take care of, though.
Hopefully someone from your side of the sea can help a bit more than we can, since we didn't see that engine in our cars.
Chris
Good stuff for sale!
PostPosted: Wed Sep 03, 2008 2:14 pm
I will post some more pic's , once I get new batteries for the camera :( .
I can see lots of similarities to an efi one , the intake to the turbo is the same , the turbo housing is the same but where this has a rubber conection in the turbo output efi cars seem to have an intercooler .
Can anyone confirm how to time the cam on there g10 ? I expect with the crank at tdc the cam pully is at 12 oclock , inline with the mark on the rocker cover , this is how a g13 is timed so just my best guess . Pulling the rocker cover off to do it the hard way , well is just too hard at the moment .
If this is the way it is ment to be it is currently out but 1/4 cam rotation and hopefully explain why there is almost no compression .
Thanks
Chris
PostPosted: Wed Sep 03, 2008 2:55 pm
just to mess with you :twisted: a 3 cylinder engine can never be 90 degrees out. :lol: the crank lobes are intrinsically separated by 120 degrees. even if the cam was 180 out, the valve timing would be 60 degrees off.
the g10 is a non-interference engine design. the cam timing should probably be set up just as listed for the mk1 and the rocker adustments should be the same.
that's a neat engine, non-intercooled, carbed, no doubt a JDM offering and new to me. thanks for the cool pic. :D
PostPosted: Thu Sep 04, 2008 12:21 am
Hi
Well I re timed the cam to what I thought it should be , it was 90 deg off :lol: So thought I would see if it had any compression , I got 130 psi on #1 cyl and only 80 psi on #2 but the batt was stuffed by then . Its on charge and I will try again . What should I be looking for , did not think 130 would have been too far off the mark for a turbo engine that is cold on a sluggish battery .
Anyhow here are a couple more pic's .
And how thought there was not much wiring to conect up :o
And thats not all of it as I seem to be missing another loom for the other side that deals with the electronic ignition . At this stage without any wiring diagrams and details on how to plumb the vacuum lines , I will never get it running . My best bet is to convert it to single point efi and a megasquirt ecu . This will be able to recieve the signal from the dissy etc so I will not have to change that . If anything happened to the carb I would never be able to get parts for it anyway .
So on the look out for a TBI injector , I would really like to keep the top manifold if at all possible so it would look original so do any tbi's have the stalk out the top like carb'sdo to screw down a filter etc . I can see an afternoon wasted at the wrecker looking for one :( .
Cheers
Chris
PostPosted: Thu Sep 04, 2008 4:02 pm
wow thats kind of cool,
you should do a comp test with a charged battery, WOT and no fuel (obviously) and report back
the lolcar family
PostPosted: Thu Sep 04, 2008 7:10 pm
take the carb hat off and get a good, clear shot of the carb. phil n ed or j,v&s might know what you have. even better, they might have parts that fit it.
is the displacement 1 liter or 660 cc?
for sure on the electronic carb you'll find a valve that cuts fuel with key operation. japanese electric carbs usually have a lot in common with pachinko machines which means that you'll probably want to find wiring documentation for it.
cool rig, though. i hope you can use it.
PostPosted: Thu Sep 04, 2008 9:40 pm
Very cool..!!
My bet it's a throttle body of some kind ....don't Know..??
Yes please take the hat off and shot me some pictures thanks ----GV&S
from the picture i can see a fuel pump so it is a carb model..??
ther should be a tab on the side or a stamp that give a carb #
t3 ragtop wrote:
suprf1y wrote:
jrjd wrote:
PostPosted: Thu Sep 04, 2008 9:53 pm
the number for are carburators are MR08
PostPosted: Fri Oct 17, 2008 4:53 pm
Well all good things come to those who wait :)
After wrapping the engine up and putting it in the corner of the shed for a rainy day a guy down country a bit advertised wrecking a cultus turbo so contacted him to get the loom complete , that way I could figure out how to wire this one up and get it running hopefully . Anyway ended getting just about all the engine and complete loom , while taking to him about what I wanted and why he says " oh I have a wiring diagrams here " , bugger but sweet . So now I have a complete spare engine and turbo etc .
Wait and see whats there when all the parts turn up but hope to get one going with the carb on it , would be cool to keep it original . He says his is out of a 1983 cultus , so a few years old now . When I uncover it I will look at the carb number and see how it compares to the post above .
Cheers
Chris
PostPosted: Fri Oct 17, 2008 5:15 pm
a.k.a Bum head
Holy poop... '83? Did they have Cultii that long ago?
PostPosted: Fri Oct 17, 2008 7:54 pm
83 was the first year of the leaf spring model cultus(swift for export markets) I have seen one of these around town, lite metallic blue with 'Turbo 3' decal on the hatch, no spoliers or sideskirts, this model ran until 85 when it was redesigned with coil springs, also the t3 got efi.
AFAIK the early T3's weren't sold anywhere outside of Japan but NZ has imported lots of used Japanese cars since the mid eighties so hence a few made it to our shores.
PostPosted: Fri Oct 17, 2008 10:07 pm
The Smuggler
I feel like Indiana Jones watching something from the past that nobody knew about suddenly appear out of the mist.
It's interestin to know good ol Suzuki was playin with these 3cyl turbo's further back that the very first 86 we saw in north America.
Why they stopped making them and selling them I can't figure out.
Fun Fuel efficient cars that are still being resurected from the piles of derelict scrap heaps.
By us cheap thrill seeking Suzuki lovers.
A 1983 3cyl turbo, that's gonna throw our Mk1/ 2 theory out the window.
Very kool to see a motor like that, we are all very interseted in following what you plan on doing with it.
To us here in North America it is a rare thing to see a motor like that.
I can hear JVS cryin from his garage as I write this.
Keep us posted with lots of pics please.
And I love this one!
PostPosted: Sat Oct 18, 2008 4:08 pm
the sound you're hearing is more likely scott spanking the monkey to the pics of a carbed turbo suzuki engine. :ez_pimp:
PostPosted: Sat Oct 18, 2008 11:11 pm
The teamswift labeling model is full of holes anyway, this early type mk1 with the rear leaf springs was sold in the US as a sprint, I know Phil N Ed has an 85 model, it's just that it's non turbo, most export markets got this early type as a 1324cc G13a where as the States got a few 993cc non turbo models and what we call a mk1 86-88 is technically only a facelift version, more like a mk1 phase 2 as they like to call them in the UK or if you like a 2nd edition 1st generation model.
Certainly is an interesting engine, I know the first generation of Daihatsu 1 litre engines (approx 1985) were carbi before they introduced the 12 valve 3 cyl gtti engine that completely changed peoples perceptions of a 'pocket rocket' in this part of the world.
PostPosted: Mon Oct 20, 2008 1:01 pm
this is cool and all, and neat that its something new, but what good is it really? even the t3s had a measly 70bhp, I dont imagine this having more than 60 really. would be cool to say you have it though
the lolcar family
PostPosted: Mon Oct 20, 2008 4:19 pm
I wouldn't be surprised if this carbed version got more power than a 90 turbo3...
Suzuki Gold Master Tech
PostPosted: Mon Oct 20, 2008 6:38 pm
i used to prefer a carb over fuel injection for the very fact that i could make more hp with them. :ez_smokin:
PostPosted: Wed Oct 22, 2008 12:31 pm
The label on the top says it makes 80PS , but since when has anyone believed a makers claim ;)
It will make the world of difference to the car it goes in as it has a 4cyl 45 hp engine now , so a lighter 3cly ~70hp engine will be a good kick in the guts .
This assuems I can get it running ok :(
Chris
PostPosted: Wed Oct 22, 2008 4:56 pm
a.k.a Bum head
Didn't notice that plate on the carb hat... can you get a closer picture of it? It's got all sorts of nice info on it. :D
PostPosted: Tue Oct 28, 2008 9:38 am
im really curious, is it really a carb engine. I know there is plenty of turbo carb stuff out there, but quickly looking at the pics, it looks as if it uses the same intake as the tbi non turbo, which happens to have injector bung bosses(on mine anyway) But my real question is, what is the object that i have circled, it looks to be an injector, and its in the spot where the injector could possibly be, and we havent gotten any more pics of the engine with the carb hat off it. Not trying to ruffle feathers, just very curious on this new find.
You know the RED area of the tach...Thats called "The FUN Zone"
91 Metro 4door T3 megasquirt, srt4 ic, stainless header with k03, 2.5" stainless exhaust
94 Mustang GT 5liter Turbo Megasquirt
http://www.UNTAMND.com
PostPosted: Tue Oct 28, 2008 6:31 pm
that's definitely a carbed turbo engine. what you have circled is more likely a pressure transducer or an air injection solenoid.
what makes me think that it's not injected in any manner is the mechanical fuel pump that can be seen in your first pics. a mechanical pump usually can't develop enough pressure or hold the pressure steady enough to be useable with an injector. the exceptions are pretty much the timed mechanical injection pumps that you find on diesel engines (but those don't require as small of a droplet in the mist as does a gas engine.)
an important function of an injector is to develop a mist of fuel which requires that the fuel pressure is higher than can be developed by a mechanically coupled diaphragm. remember that the fuel delivery of a mechanical pump changes with engine rpms (usually at the rate of one stroke per revolution.)
conversely, a high pressure electric fuel pump doesn't work very well with a carb. if the fuel is delivered at too high a pressure, the float needle gets blown off it's seat, the bowl overflows, and floods the engine.
PostPosted: Tue Oct 28, 2008 8:33 pm
a.k.a Bum head
Part of the PCV system?
PostPosted: Tue Oct 28, 2008 9:29 pm
After looking at the pic of the other engine, it looks to be a vacuum port.
Very nifty little engine and setup thats for sure. Keep us posted with how things turn out and what else you find for info on it.
PostPosted: Wed Oct 29, 2008 5:35 pm
I can make out 'knock controlled'....
We demand pics inside the presumed carb hat! =)
Corviar Turbo, G10 turbo Inno Mini, Turbo VW bug.....Next?
