It is currently Sat Feb 24, 2018 9:25 pm
 Post subject: Oil pan ,pickup
PostPosted: Sun Mar 03, 2013 12:29 pm
I have modified my oil pan and pickup to use the 89 turbo Efi g10 engine in my Suzuki Lj 80 ,since then I have done a spring over axle conversion and I want to replace the pan and pick up with the stock one .Can anyone tell me if I can use a non turbo engine pan and pickup ,I'd much rather have the pan before I pull the one off the engine , thanks Craig
 Post subject: Re: Oil pan ,pickup
PostPosted: Sun Mar 03, 2013 1:35 pm
there's no difference between the 89-91 mk2 turbo3 oil pan and oil pickup tube and the normally aspirated g10 oil pan and oil pickup tube. the oil pans are all alike from 89 through 95 g10 engines. on newer g10 engines the only difference is the hole in the front lip of the oil pan for the crank sensor.
PostPosted: Sun Mar 03, 2013 2:11 pm
Thank you T3 ragtop for that info ,have a great day!
PostPosted: Tue Apr 23, 2013 1:26 pm
i too agree with ragtop
