It is currently Tue Oct 17, 2017 3:17 am
PostPosted: Sun May 19, 2013 1:25 pm
Hey guys, just wanted to ask about the g10t, since I've been reading that there are some difference on the later model firefly turbo having hydraulic lifters and the rest of the turbo lineup has mechanical. Which is the preferred engine in you guys' opinion? I am assuming that the hydraulic version of these motors are even more difficult to find than the mechanical version, so I guess I am just trying to see what is the ideal setup, and then trying to be realistic about what is actually practical to find. Thanks!
PostPosted: Sun May 19, 2013 1:40 pm
Hydraulic is more common as they are in 2nd & 3rd gen vehicles.
The MK1 vehicles are mechanical, the head is a different configuration
with Hemi configuration and is a better flowing head than the
hydraulic valve setup.
(Edit): See Superfly clarification below.
(I was not specifically referring to G10T, just G10
..should have been more specific)
Last edited by JamalSpelling on Sun May 19, 2013 2:21 pm, edited 2 times in total.
PostPosted: Sun May 19, 2013 1:59 pm
a.k.a Bum head
Keep in mind that finding the turbo electrical and other bits for the Mk2 engines is tough since they were only sold in the Great White North.
PostPosted: Sun May 19, 2013 2:15 pm
There are no turbo 3's with mechanical lifters. The first gen did not use lifters, but had a rocker arm setup with mechanical lash adjustment. The first gen is the better motor. The hydraulic ones were Canada only, so almost impossible to find in the US.
PostPosted: Sun May 19, 2013 2:33 pm
@ssclown
I'm not an engineer but it seems to me a no brainer that a solid lifter is better than a hydraulic lifter because its lighter, therefore lower reciprocating valvetrain mass, and simpler, therefor less to go wrong, and because its one piece of solid steel it probably does a better job of lifting the rocker arm than an oil filled multi part hydraulic lifter. The only advantage I know of for hydraulic lifters is they are maintenance free, unless one collapses, something which cant happen to a solid tappet.
I seem to remember that the 340 cubic inch six pack Dodge motor, built for performance, used solid lifters.
PostPosted: Sun May 19, 2013 6:44 pm
The Toyota Echo comes with solid lifters, the Swift GTi, with hydraulics. Therefore, I would conclude that hydraulic lifters are better for high performance :lol:
PostPosted: Mon May 20, 2013 12:36 am
While they would be nice for ease of maintenance and might be better on the margins as far as better performance, I just don't think that the rarity of parts or the difficulty of working on one of those would be worth it. Sometimes I think Suzuki has ofrgotten the ole' US of A when it comes to cars :(
PostPosted: Mon May 20, 2013 2:17 am
@ssclown
The AAR 'cuda with a 340 six pack comes with solid lifters and the Edsel Corsair comes with hydraulic lifters.
Therefore, I would conclude that solid lifters are better for high performance.
PostPosted: Mon May 20, 2013 3:08 am
Do you blame them? the average american is not interested in driving a small car and thats pretty much what they build, the cost of having a dealer and parts network would be huge in a country the size of the States and if you don't have a range of large SUV's to carry the rest of the model range it's hard to do business.
I see they have sold well over 3 million new suzuki swifts since the new model came out in 2005.
http://3d-car-shows.com/2013/suzuki-swi ... worldwide/
As for solid lifters, I have spent plenty of time researching this, I beleive there will be a small gain at high rpm but I don't think the gain will be worth the effort.
PostPosted: Mon May 20, 2013 6:20 am
There is no gain in power. The only benefit, from a performance perspective, is the ability to rev higher without the lifters "pumping up", or over compensating for the lash, and actually keeping the valves open when they're supposed to be seated. Something that doesn't happen in our application. 50 years ago, that was a problem on large pushrod V8's with tiny little hydraulic lifters, although knowing how to set them practically eliminates the problem. In the 80's, I was using hydraulics to 7000 RPM in small block chev motors with no problem.
PostPosted: Mon May 20, 2013 6:50 am
@ssclown
I checked it and it isn't the 340 six pack that comes with solid lifters its the General Motors ZL1 that came in some 1969 Camaros and Corvettes. It had solid lifters so it could rev higher, up tp 8,000 rpm, than hydraulic lifters.
I owned a '68 Barracuda 340S and a Z28 and I remember the Haynes or Chilton for one of them showed valve gap specs for some years with solid lifters, but I was mistaken in thinking it was the Barracuda, it was the Z28.
But anyway, the solid lifters rev higher, which in my opinion is better, and which is why I own ten or eleven '85 to '88 MK1 Fireflies, Forsas and Sprints which do not have hydraulic lifters and I only own three of the '89 and up Swifts, Fireflies and Geos which do have hydraulic lifters.
cron
