It is currently Fri Oct 20, 2017 12:23 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Sat Nov 30, 2013 4:23 pm
Ok i had a chance to do some more diggin. I took the air filter off and watched the maf while i played with the ut throttle and it seems to move instantaneously. I did the warm engine compression test with the throttle at wot and the numbers thia time were 151/147/146. So not thinkin its the bottom end. While doing the comp test i changed out the auto lite spark plugs for ngk ones oem number and ot now idels a lot better but still low. It just doesn't die now. With the higher idle i checked timing and it was at 15 deg. I pulled it to 10 and it got a little better. I pulled off the charge pipe and looked in the throttle body. Its very clean before the flaper and a bit dirty after it. But i can see the metel of the intake so its not super gummy or anything.
PostPosted: Sun Dec 01, 2013 3:30 am
So now there is a new development. I let it cool down after the compression test and checking everything out and a short drive. Went out to drive it to work and now the throttle is an on off switch. Not sure if this is a connected issue or a new one. :huh:
PostPosted: Sun Dec 01, 2013 10:59 am
bad tps, connector, or wiring.
you really need to get a factory service manual (fsm) and work the diagnostics from the fsm's flow chart.
PostPosted: Tue Dec 03, 2013 2:45 pm
So i got to tginking about it and asked my dad and as far as either of us could remember it had the factory o2 sensor in the exhaust. Changed that out this morning and wala it idles at 800ish rpm as of current.
